Acer SP714-61N Compal LA-K501P Schematic
The Compal GH4PX (LA-K501P) is a 13.3-inch convertible motherboard powered by the Qualcomm SC8180X octa-core 7nm FinFET SoC. The platform integrates LPDDR4 memory configured as 64-bit dual-channel with two 16GB packages. System power management is handled by a suite of Qualcomm PMICs including PMC8180C, dual PMC8180, PMK8002, and dual PMC1000H. Charging is managed by the SMB2351 2S charger IC. The embedded controller is an ENE KB9022. Audio processing is provided by the WCD9341 codec paired with dual WSA8815 amplifiers. Wireless connectivity uses the WCN3998 module. The board includes dual FSUSB42UMX USB-C multiplexers for USB3.1 Gen2 and DP Alt Mode support.
Q: What EC/KBC is used on the GH4PX?
A: The embedded controller is an ENE KB9022.
A: The charging architecture uses an SMB2351 2S charger IC.
Q: What memory configuration does the GH4PX use?
A: The board uses LPDDR4 memory in a 64-bit dual-channel configuration with two 16GB packages.
Q: What audio components are present on this board?
A: The audio subsystem consists of a WCD9341 codec and dual WSA8815 amplifiers.
Reuse permitted only with source attribution.
| Model | GH4PX |
| Project Code | LA-K501P |
| Board Number | LA-K501P |
| Revision | 0.12 |
| Date | 2020.03.20 |
| CPU Platform | Qualcomm SC8180X |
| EC / KBC | ENE KB9022 |
| Audio Codec | WCD9341 |
| Audio Amplifier | WSA8815 X2 |
| Charging IC | SMB2351 |
| Charger Architecture | 2S Charger |
| Power IC(s) | PMC8180C, PMC8180 x2, PMK8002, PMC1000H x2 |
| RAM Type | LPDDR4 |
| RAM Architecture | 64 BIT x2 pcs 16GB |
| WiFi / WLAN IC | WCN3998 |
| USB Hub IC | FSUSB42UMX |
| Graphics Architecture | Qualcomm Adreno (integrated in SC8180X) |
LA-K501P
LA-K501P
Qualcomm SC8180X
KB9022
WCD9341
WSA8815 X2
SMB2351
PMC1000H X2
PMC8180 X2
PMC8180C
PMK8002
LPDDR4
WCN3998
FSUSB42UMX
LA-K501P
LA-K501P
Qualcomm SC8180X
KB9022
WCD9341
WSA8815 X2
SMB2351
PMC1000H X2
PMC8180 X2
PMC8180C
PMK8002
LPDDR4
WCN3998
FSUSB42UMX
