Acer Quanta RPL-H_ZYP-V02-RAMP ZGD Schematic
The Quanta ZGD project is a Raptor Lake-H platform paired with a Raptor Lake-PCH, utilizing a BGA1744 CPU package. Graphics are handled by a discrete GN21-MB2 115W GPU with gDDR6 memory configured as 2CH x 512M x 16 x 4pcs. The system supports up to two DDR5 4800MHz SODIMM modules. The embedded controller is an IT5570E, and the audio codec is an ALC245. A 16M SPI flash is used for BIOS storage. Connectivity includes an I2600-CG LAN controller, CNVi/Discrete WLAN, and a PI3HDX12211ZHEX HDMI redriver. USB-C functionality is managed by a CCG6 CYPD6128-48LQXI PD controller and PS8811 USB3 redrivers. Thunderbolt 4 support is provided by an Intel Hayden Bridge JHL9040R re-timer. Power management includes an SLGC55544CVTR IC, and LED control is handled by an ene6K5130 driver.
A: The embedded controller is an IT5570E.
Q: What BIOS flash capacity is used?
A: The BIOS SPI flash is 16M.
Q: What is the GPU configuration?
A: The dGPU is a GN21-MB2 115W with gDDR6 memory configured as 2CH x 512M x 16 x 4pcs.
A: The system uses DDR5 4800MHz memory in two SODIMM slots.
Q: What Thunderbolt controller is used?
A: Thunderbolt 4 is handled by an Intel Hayden Bridge JHL9040R re-timer.
| Project Code | ZGD |
| Document Number | 1251 |
| Revision | A1A |
| Date | Monday, August 14, 2023 |
| CPU Platform | Raptor Lake-H (Raptor-H) |
| PCH / Southbridge | Raptor Lake-PCH |
| CPU Package | BGA1744 |
| GPU Type | GN21-MB2 115W |
| Graphics Architecture | gDDR6 |
| dGPU Chip Number | GN21-MB2 2CH x 512M x 16 x 4pcs |
| EC / KBC | IT5570E |
| Audio Codec | ALC245 |
| BIOS / SPI Flash | 16M |
| RAM Type | DDR5 4800MHz |
| RAM Architecture | SODIMM |
| Card Reader IC | D.B.SD3.0 |
| LAN IC | I2600-CG |
| WiFi / WLAN IC | CNVi/Discrete |
| HDMI Level Shifter | PI3HDX12211ZHEX |
| USB Hub IC | PS8811 QFN36 GTR2-A3 |
| Charging IC | CCG6 CYPD6128-48LQXI |
| Power IC(s) | SLGC55544CVTR |
| LED Driver | ene6K5130 |
| Thunderbolt Controller | Intel Hayden Bridge JHL9040R |
Raptor Lake-H
BGA1744
GN21-MB2 115W
GDDR6
GN21-MB2 2CH X
IT5570E
ALC245
DDR5
D.B.SD3.0
I2600-CG
PI3HDX12211ZHEX
SLGC55544CVTR
ENE6K5130
HAYDEN BRIDGE JHL9040R
Raptor Lake-H
BGA1744
GN21-MB2 115W
GDDR6
GN21-MB2 2CH X
IT5570E
ALC245
DDR5
D.B.SD3.0
I2600-CG
PI3HDX12211ZHEX
SLGC55544CVTR
ENE6K5130
