Acer Predator PH16-71 ZGRC_ZGRE_ZGRB_ZGRD DAZGRMB2AC0 Schematic
This Quanta Helios (ZGRC/ZGRE) motherboard is built on the Raptor Lake-HX platform with a BGA1744 CPU socket. Memory architecture consists of two DDR5 SODIMM slots supporting up to 32GB each at 4800MHz across Channel A and Channel B. The discrete GPU options include NVIDIA GN20-E3, GN20-E5/E6/E7, GN20-P1, and GN21/WN21-MB1 GB5B-256VRAM with gDDR6 memory, managed by a PI3DPX8121ZLDEX eDP mux and a 16M VBIOS. The embedded controller is an IT5570, and the audio codec is an ALC3324. Connectivity is handled by an Intel Maple-Ridge JHL8540-QUBZ Thunderbolt controller, a CCG6 CYPD6227-48LQXI PD controller, PS8811QFN36GTR2-A3 USB re-drivers, and an E3100G LAN IC. The system includes a 16M SPI BIOS flash and an ene6K5130 LED driver.
A: The board numbers are ZGRC and ZGRE, with the project code Helios.
A: The embedded controller is an IT5570.
A: The dGPU options include NVIDIA GN20-E3, GN20-E5/E6/E7, GN20-P1, and GN21/WN21-MB1 GB5B-256VRAM with gDDR6 memory.
A: The BIOS is a 16M SPI flash.
Reuse permitted only with source attribution.
| Project Code | Helios(ZGRC) |
| Board Number | ZGRC / ZGRE |
| CPU Platform | Raptor Lake-HX |
| CPU Socket | BGA1744 |
| RAM Type | DDR5 |
| RAM Speed | 4800MHz |
| RAM Quantity / Slots | SODIMM1, SODIMM2 |
| GPU Type | NVIDIA |
| dGPU Chip Number | GN20-E3, GN20-E5/E6/E7, GN20-P1, GN21/WN21-MB1 GB5B-256VRAM |
| Graphics Architecture | gDDR6 |
| eDP Mux | PI3DPX8121ZLDEX |
| VBIOS | 16M |
| EC / KBC | IT5570 |
| Audio Codec | ALC3324 |
| LAN IC | E3100G |
| WLAN | CNVi/Discrete |
| Thunderbolt Controller | Intel Maple-Ridge JHL8540-QUBZ |
| PD Controller | CCG6 CYPD6227-48LQXI |
| USB Re-driver | PS8811QFN36GTR2-A3 |
| BC1.2 | SLGC55544CVTR |
| Card Reader IC | D.B.S. |
| Charging IC | TCP0 |
| Thermal Sensor | SMB |
| LED Driver | ene6K5130 |
| BIOS / SPI Flash | SPI |
| BIOS Flash Capacity | 16M |
| RAM Max Capacity | 32GB per SODIMM |
Raptor Lake-HX
DDR5
GB5B-256VRAM
GN20-E3
GN20-E5
GN20-E6
GN20-E7
GN20-P1
GN21
WN21-MB1
GDDR6
PI3DPX8121ZLDEX
IT5570
ALC3324
E3100G
MAPLE-RIDGE JHL8540-QUBZ
PS8811QFN36GTR2-A3
SLGC55544CVTR
TCP0
ENE6K5130
Raptor Lake-HX
DDR5
GB5B-256VRAM
GN20-E3
GN20-E5
GN20-E6
GN20-E7
GN20-P1
GN21
WN21-MB1
GDDR6
PI3DPX8121ZLDEX
IT5570
ALC3324
E3100G
PS8811QFN36GTR2-A3
SLGC55544CVTR
TCP0
ENE6K5130
