acer icl50-51 ick70-71 la-3551p_rev 2.0 schematic
acer=1=icl50-51 ick70-71 la-3551p_rev 2.0 schematic.pdf
This Compal LA-3551P schematic, revision 1.0 dated August 15, 2007, documents the ICL50/ICK70 motherboard platform. The board is built around an Intel Merom processor in a Socket P package, paired with the Intel Crestline (PM965/GM965) chipset and the Intel ICH8-M southbridge. Graphics are handled by an ATI MXM/B module. The system memory architecture consists of dual-channel DDRII, supported by two 200-pin DDRII SO-DIMM slots. The embedded controller is an ENE KB926, and the audio codec is an ALC268. The board utilizes an ICS9LPRS365 clock generator and an ADM1032 thermal sensor. Networking is provided by a BCM5787M Gigabit Ethernet controller, and a R5C833 card reader IC is present. The schematic also indicates a dedicated BIOS flash component.
A: The board number is LA-3551P, and the project code is ICL50/ICK70.
A: The embedded controller is an ENE KB926.
Q: What is the CPU platform and socket type?
A: The platform is Intel Merom with Crestline (PM965/GM965), and the CPU socket is Socket P.
A: It supports dual-channel DDRII memory via two 200-pin DDRII SO-DIMM slots.
| Model | ICL50/ICK70 M/B LA-3551P |
| Project Code | ICL50/ICK70 |
| Board Number | LA-3551P |
| Date | Wednesday, August 15, 2007 |
| CPU Platform | Intel Merom Processor with Crestline (PM965/GM965) |
| CPU Socket | Socket P |
| PCH / Southbridge | Intel ICH8-M |
| GPU Type | ATI MXM/B |
| EC / KBC | ENE KB926 |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | BIOS |
| RAM Type | DDRII |
| RAM Quantity / Slots | 200pin DDRII-SO-DIMM X2 |
| Card Reader IC | R5C833 |
| LAN IC | BCM5787M |
| WiFi / WLAN IC | WLAN |
| Thermal Sensor | ADM1032 |
| Clock Generator | ICS9LPRS365 |
