acer aspire 5315_5320 compal_la-3551p_rev1.0 schematic
acer aspire 5315_5320=1=compal_la-3551p_rev1.0.pdf
This Compal LA-3551P motherboard schematic, revision 1.0 dated April 23, 2007, documents the ICL50/ICK70 M/B platform. The design is built around an Intel Merom Processor with Crestline (PM965/GM965) chipset and an Intel ICH8-M Southbridge, supporting DDRII memory in a dual-channel configuration via two 200-pin SO-DIMM slots. Graphics processing is handled by an ATI MXM/B module. The embedded controller is an ENE KB926, while audio is managed by an ALC268 codec. Networking is provided by a BCM5787M Gigabit LAN controller. The system also features an R5C833 card reader, an ADM1032 thermal sensor, and an ICS9LPRS365 clock generator.
A: The board number is LA-3551P, revision 1.0.
A: The embedded controller is an ENE KB926.
Q: What is the CPU platform and chipset configuration?
A: The platform is an Intel Merom Processor with Crestline (PM965/GM965) and an Intel ICH8-M Southbridge.
Q: What type of memory architecture does this board support?
A: It supports DDRII memory in a dual-channel configuration using two 200-pin SO-DIMM slots.
| Model | ICL50/ICK70 M/B |
| Project Code | ICL50/51, ICK70/ICK71 |
| Board Number | LA-3551P |
| Date | Monday, April 23, 2007 |
| CPU Platform | Intel Merom Processor with Crestline(PM965/GM965) |
| Document Number | B148 |
| PCH / Southbridge | Intel ICH8-M |
| GPU Type | ATI MXM/B |
| EC / KBC | ENE KB926 |
| Audio Codec | ALC268 |
| LAN IC | BCM5787M |
| RAM Type | DDRII |
| RAM Quantity / Slots | 200pin DDRII-SO-DIMM X2 |
| Card Reader IC | R5C833 |
| Thermal Sensor | ADM1032 |
| Clock Generator | ICS9LPRS365 |
