acer f5-522 quanta zab da0zabmb6e0
The Quanta ZAB motherboard is designed for AMD Carrizo/Bristol/Stoney Ridge platforms with a BGA 968 socket. The system uses DDR4-SODIMM memory across two channels. Graphics are handled by a discrete R16M GPU available in R16M-M1-70 or R16M-M1-30 configurations, paired with DDR3 VRAM in 2GB or 4GB configurations. The embedded controller is an NPCT650, and the audio codec is an ALC255-CG. The BIOS is stored on an 8MB SPI ROM. Power management includes BQ24737 battery charging, along with RT8068, RT8237, ISL62771, RT6575, and G5316+ regulators. The board integrates an RTL841B for both LAN and card reader functions, an ASM 1061 USB hub, and an M.2 WLAN+BT module. The TPM is also handled by the NPCT650.
A: The BIOS is stored on an 8MB SPI ROM.
A: The embedded controller is an NPCT650, which also handles the TPM function.
Q: What GPU configurations are available on this motherboard?
A: The board supports R16M-M1-70 (25W) and R16M-M1-30 (25W) discrete GPUs, with VRAM configurations of 4 pcs DDR3 256Mb x16 (2GB) or 8 pcs DDR3 256Mb x16 (4GB).
A: The battery charger IC is a BQ24737.
| Project Code | ZAB |
| Board Number | ZAB |
| Revision | A |
| Date | Friday, January 29, 2016 |
| CPU Platform | Carrizo(15h) 60h-6Fh / Bristol(15h) 65h-6Fh / STONEY(15H) 70h-7Fh |
| EC / KBC | NPCT650 |
| Audio Codec | ALC255-CG |
| BIOS / SPI Flash | SPI ROM 8MB |
| Charging IC | BQ24737 |
| Power IC(s) | RT8068 / RT8237 / ISL62771 / RT6575 / G5316+ |
| RAM Type | DDR4-SODIMM |
| RAM Architecture | Channel A (TYP1) / Channel B (TYP1 & 3) |
| Card Reader IC | RTL841B |
| LAN IC | RTL841B |
| WiFi / WLAN IC | M.2 WLAN+BT w/ Debug |
| GPU Type | R16M GPU |
| Graphics Architecture | R16M-M1-70 25W / R16M-M1-30 25W |
| dGPU Chip Number | R16M-M1-70 / R16M-M1-30 |
| dGPU VRAM Type | DDR3_256 Mb x16 |
| dGPU VRAM Quantity | 4 pcs = 2 GB / 8 pcs = 4 GB |
| USB Hub IC | ASM 1061 |
| TPM | NPCT650 |
Bristol 15H 65H-6FH
Carrizo
Stoney 15H 70H-7FH
NPCT650
ALC255-CG
BQ24737
G5316
ISL62771
RT6575
RT8068
RT8237
RTL841B
RTL841B
R16M GPU
R16M-M1-30
R16M-M1-70
ASM1061
Bristol 15H 65H-6FH
Carrizo
Stoney 15H 70H-7FH
NPCT650
ALC255-CG
BQ24737
G5316
ISL62771
RT6575
RT8068
RT8237
RTL841B
RTL841B
R16M GPU
R16M-M1-30
R16M-M1-70
ASM1061
