acer aspire one 522-ao522 compal la-7072p touchpad rev-1.0 1
This Compal Electronics P0VE6 schematic, revision 0.1, is dated Monday, October 11, 2010. The document is classified as Compal Secret Data and is the proprietary property of Compal Electronics, Inc. The schematic page details a Touch pad Custom design, featuring a PCB reference of PCB_LS7073P. The touchpad assembly includes a main connector JP2 (ACES_85201-0605CONN) for motherboard connection and a secondary connector JTP1 (ACES_85201-0405NCONN) for the touchpad board. The design incorporates two tactile switches, SW1 and SW2, identified as SMT1-05-A_4P components, corresponding to left and right buttons. ESD protection is provided by a PJDLC05C_SOT23-3 diode. The layout includes an FFC connection to the motherboard (ZZZ2FFC_to MB45) and to the touchpad (ZZZ3FFC_to TP45).
Q: What is the project code and revision of this Compal schematic?
A: The project code is P0VE6, and the schematic revision is 0.1.
Q: What is the document date for this Compal P0VE6 schematic?
A: The document is dated Monday, October 11, 2010.
Q: What connectors are used for the touchpad interface on this Compal P0VE6 board?
A: The main motherboard connector is JP2 (ACES_85201-0605CONN), and the touchpad board connector is JTP1 (ACES_85201-0405NCONN).
| Project Code | P0VE6 |
| Document Number | P0VE6 Schematics |
| Revision | 0.1 |
| Date | Monday, October 11, 2010 |
