acer extensa 5210 wistron_dellen_revsa schematic
acer extensa 5210=1=wistron_dellen_revsa.pdf
This Dell motherboard, manufactured by Wistron Corporation under project code 91.4V401.001 and board number 48.4T307.0SA revision 06259-SA2, is built around the Yonah 478 Celeron M mobile CPU platform paired with an ICH7M southbridge. The system BIOS is stored on a W25X80-V SPI flash IC. Embedded controller functions are handled by a Winbond WPC8768L KBC. Audio is managed by an ALC268 codec, while wired networking is provided by a BCM5787M Gigabit LAN controller. The charging subsystem utilizes an ISL6255 charger IC, supported by a power delivery network including MAX8744, RTM865T-433, TPS51100, APL5312, APL5912, MAX8770, and MAX8717 regulators. Memory architecture is DDR2 operating at 533/667 MHz. The board also integrates a 5-in-1 card reader and supports a/b/g/n wireless connectivity.
A: The BIOS is stored on a W25X80-V SPI flash IC.
A: The embedded controller is a Winbond WPC8768L KBC.
A: The charging IC is an ISL6255.
A: The memory architecture is DDR2 operating at 533/667 MHz.
| Project Code | 91.4V401.001 |
| Board Number | 48.4T307.0SA |
| Revision | 06259-SA2 |
| Date | Tuesday, January 16, 2007 |
| CPU Platform | Yonah 478 Celeron M |
| PCH / Southbridge | ICH7M |
| EC / KBC | WPC8768L |
| EC/KBC Package | Winbond |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | W25X80-V |
| Charging IC | ISL6255 |
| Power IC(s) | MAX8744, RTM865T-433, TPS51100, APL5312, APL5912, MAX8770, MAX8717 |
| RAM Type | DDR2 |
| RAM Architecture | 533/667 MHz |
| LAN IC | BCM5787M |
| WiFi / WLAN IC | a/b/g/n |
| Card Reader IC | 5 in 1 |
| Document Number | A3143 |
91.4V401.001
48.4T307.0SA
Yonah
ICH7M
WPC8768L
ALC268
W25X80-V
ISL6255
APL5312
APL5912
MAX8717
MAX8744
MAX8770
RTM865T-433
TPS51100
BCM5787M
5 IN 1
91.4V401.001
48.4T307.0SA
Yonah
ICH7M
WPC8768L
ALC268
W25X80-V
ISL6255
APL5312
APL5912
MAX8717
MAX8744
MAX8770
RTM865T-433
TPS51100
BCM5787M
5 IN 1
