acer emachines d620 wistron_yukon_revsa schematic
acer emachines d620=1=wistron_yukon_revsa.pdf
The Wistron Yukon SA motherboard, project code 91.4BC01.001 with PCB P/N 48.4BC01.0SA revision 08226-SA, is an AMD K8 Rev. G platform featuring the ATI RS690M integrated graphics and SB600 southbridge. The system memory architecture supports two DDR2 SODIMM slots operating at DDR II 533/667/800. The embedded controller is a Winbond WPC8773L, and the BIOS SPI flash is a W25X80-V. Audio is handled by the Realtek ALC268 codec, while networking is provided by a Marvell 8040 LAN controller. Wireless connectivity uses a G792 802.11a/b/g/n Mini Card. The charging subsystem is managed by a dedicated battery charger IC. Additional onboard controllers include the G1432 card reader, G1412 USB hub, and 9LPRS502 (RTM875T-605) clock generator.
A: The BIOS SPI flash is a W25X80-V.
A: The embedded controller is a Winbond WPC8773L.
A: The motherboard supports two DDR2 SODIMM slots with DDR II 533/667/800 memory.
Q: What is the GPU architecture on this motherboard?
A: The integrated graphics is an ATI RS690M.
| Brand | Wistron |
| Project Code | 91.4BC01.001 |
| Board Number | 48.4BC01.0SA |
| Revision | 08226-SA |
| Date | Thursday, July 03, 2008 |
| CPU Platform | AMD K8 Rev. G |
| PCH / Southbridge | SB600 |
| GPU Type | ATI RS690M |
| EC / KBC | WPC8773L |
| EC/KBC Manufacturer | Winbond |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | W25X80-V |
| BIOS Flash Capacity | 1MB (8Mbit) |
| Charging IC | SAD+BAT+Battery Charger |
| RAM Type | DDR2 SODIMM |
| RAM Architecture | DDR II 533/667/800 |
| LAN IC | Marvell 8040 |
| WiFi / WLAN IC | G792 802.11a/b/g/n Mini Card |
| Card Reader IC | G1432 |
| USB Hub IC | G1412 |
| CLK GEN IC | 9LPRS502 (RTM875T-605) |
