acer e1-472g wistron ea40-hw ulv 12243-1 1
This Wistron EA40_HW ULT1 motherboard, documented under project code 91.4YN01.001 and PCB P/N 12243, is built around an Intel Haswell CPU in a BGA1168 package, specifically the BHASWELL-6-GP71.HASWE.G0U model. The platform supports dual-channel DDR3L 1333/1600 memory across two slots. Discrete graphics is provided by an N14P GPU with 2GB of DDR3 VRAM. The system EC/KBC is an ITE8587, and the audio codec is an ALC3225. BIOS storage is handled by an 18MB SPI flash. The charging architecture is managed by a BQ24737 charger IC, with system power delivery handled by a combination of TPS51225, TPS51622, RT8207, SYW232, TPS51728RHA, and RT8208 regulators. Networking and card reading are integrated via a Realtek RTL8411AA-CG controller, while thermal monitoring is provided by an NCT7718W sensor. USB charging is supported by a TPS2546 hub IC.
A: The motherboard uses an 18MB SPI Flash for BIOS storage.
A: The embedded controller is an ITE8587.
A: The charging IC is a BQ24737, with a charger architecture that outputs 3D3V_S5 and BT+.
Q: What is the discrete GPU configuration?
A: The discrete GPU is an N14P with 2GB of DDR3 VRAM.
| Brand | Wistron |
| Project Code | 91.4YN01.001 |
| Board Number | EA40_HW ULT1 |
| Document Number | EA40_HU_ULT |
| Revision | A3 |
| Date | Monday, May 13, 2013 |
| CPU Platform | Haswell |
| CPU Model | BHASWELL-6-GP71.HASWE.G0U |
| CPU Socket | BGA1168 |
| GPU Type | N14P |
| Graphics Architecture | DDR3 2GByte VRAM |
| EC / KBC | ITE8587 |
| Audio Codec | ALC3225 |
| BIOS / SPI Flash | 18MB SPI Flash |
| Charging IC | BQ24737 |
| Charger Architecture | BQ24737 3D3V_S5 BT+ 44 OUTPUTS BQ24737 INPUTS CHARGER DC BATOUT |
| Power IC(s) | TPS51225, TPS51622, RT8207, SYW232, TPS51728RHA, RT8208 |
| RAM Type | DDR3L 1333/1600 |
| RAM Architecture | Channel A, Channel B |
| RAM Quantity / Slots | Slot 1, Slot 2 |
| Card Reader IC | RTL8411AA-CG |
| LAN IC | Realtek RTL8411AA-CG |
| WiFi / WLAN IC | WLAN + BT PCIE / USB2.0 |
| HDMI Level Shifter | HDMI 1.4a |
| Thermal Sensor | NCT7718W |
| USB Hub IC | TPS2546 |
91.4YN01.001
EA40_HW ULT1
Haswell
N14P
DDR3 2GByte VRAM
IT8587
ALC3225
BQ24737
RT8207
RT8208
SYW232
TPS51225
TPS51622
TPS51728RHA
RTL8411AA-CG
RTL8411AA-CG
USB2.0
NCT7718W
TPS2546
91.4YN01.001
EA40_HW ULT1
Haswell
N14P
DDR3 2GByte VRAM
IT8587
ALC3225
BQ24737
RT8207
RT8208
SYW232
TPS51225
TPS51622
TPS51728RHA
RTL8411AA-CG
RTL8411AA-CG
USB2.0
NCT7718W
TPS2546
