File Request ACER C733 CHROMEBOOK
gullu
Please remove unrolment
  • lock no 3.BIN
gullu
this pic
gullu
this file stuck in here,i have changed to another network but its still the same
Vahab Hemmati
Support Team
i just patched your file and its done correctly
it should work
please check carefully
gullu
This is the same problem,it doesn't want to connet wifi.I Think there is a problem with the file,because if i install the original file,the device can connect wifi
Vahab Hemmati
Support Team
i just removed enrollment error
as you wanted
if you can connect wifi with old file , then what is the problem ?
gullu
as you wanted
when i install the original file,OS is locked
