acer aspire e5-574 e5-574g e5-574t zoro(ba50) sl zrw zrwa skl ult
The Quanta ZRW project (Document Number 3A148, dated July 20, 2015) is a motherboard based on the SKY LAKE ULT 15W CPU platform. The system block diagram indicates support for discrete GPU options including N16S-GT/GC6 and N16V-GM/WO GC6. The embedded controller is an IT8987, and the audio codec is an ALC255. The BIOS/SPI flash configuration is 8M+4M. Power management is handled by a BQ24780RUYR battery charger and multiple voltage regulators including NB681GD-Z, ISL95859HRTZ-T, RT8068AZQW, RT8237CZQW, TPS51225, and UP1658RQKF. Memory architecture is Dual Channel DDR III using DDR3L-SODIMM modules. Networking is provided by a Realtek RTL8111H LAN IC, and the card reader controller is an RTS5170.
A: The embedded controller is an IT8987.
Q: What is the BIOS/SPI flash configuration?
A: The BIOS/SPI flash configuration is 8M+4M.
A: The battery charger IC is a BQ24780RUYR.
Q: What LAN IC is used?
A: The LAN IC is a Realtek RTL8111H.
This Quanta Computer Inc. USB board, documented under project "USB board" with document number ZS8, reached revision 3B as of Tuesday, May 05, 2015. The schematic includes revision history entries from January 2014 through August 2014, documenting modifications such as USB trace EMI filter addition, resistor value changes from 91 ohm to 90.9 ohm, connector pin definition updates, and SD card circuit adjustments including LDO addition for high-speed read speed issues. The board features USB connectors CN1 and CN2, with associated passive components including capacitors C1 (0.1u/10V), C3 (100u/6.3V), C14 (70p/50V), and C10 (2p). Mounting holes HOLE1 through HOLE5 are defined with specific pad types including H-TC102BSD102PT1, O-ZRT-11, SPAD-ZRT-1NP1, and H-C98D98N1.
Q: What is the document number and revision of this USB board?
A: The document number is ZS8, and the revision is 3B, dated Tuesday, May 05, 2015.
Q: What modifications were made to the USB traces in revision history?
A: An EMI filter was added on USB trace, and resistors R5692, R6005, R6006, R6007, R6008, R6009 were changed from 91 ohm to 90.9 ohm.
Q: What SD card circuit changes were implemented?
A: An LDO was added for high-speed SD card read speed fail issue, and resistors R12, R5686, R5690, R5691, R10 were changed from 0 ohm to shortpad.
| Brand | Quanta |
| Project Code | ZRW |
| Document Number | 3A148 |
| Date | Monday, July 20, 2015 |
| CPU Platform | SKY LAKE ULT 15W |
| GPU Type | N16S-GT / GC6 / N16V-GM / WO GC6 |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | 8M+4M |
| Charging IC | BQ24780RUYR |
| Power IC(s) | NB681GD-Z / ISL95859HRTZ-T / RT8068AZQW / RT8237CZQW / TPS51225 / UP1658RQKF |
| RAM Type | DDR3L-SODIMM |
| RAM Architecture | Dual Channel DDR III |
| LAN IC | RTL8111H |
| Card Reader IC | RTS5170 |
| Project | USB board |
| Revision | 3B |
| Date | Tuesday, May 05, 2015 |
| Document Number | ZS8 |
SKY Lake ULT
GC6
N16S-GC6
N16S-GT
N16S-WO
N16V-GM
IT8987
ALC255
BQ24780RUYR
ISL95859HRTZ-T
NB681GD-Z
RT8068AZQW
RT8237CZQW
TPS51225
UP1658RQKF
RTL8111H
SKY Lake ULT
GC6
N16S-GC6
N16S-GT
N16S-WO
N16V-GM
IT8987
ALC255
BQ24780RUYR
ISL95859HRTZ-T
NB681GD-Z
RT8068AZQW
RT8237CZQW
TPS51225
UP1658RQKF
RTL8111H
