acer aspire e5-471g v3-472p quanta zq0 rev 3a schematic 1
The Quanta Computer Inc. ZQ0 project, board number 3A146, is a Brodwell ULT 15W platform featuring an integrated GT3 IMC MCP 1168-pin GPU. The system utilizes dual-channel DDR3L-SODIMM memory across channels CHA and CHB, supporting 1066/1333/1600 MHz. The BIOS/SPI flash configuration is 8M+4M. The embedded controller is an IT8587, and the audio codec is an ALC283. Power management is handled by a BQ24737RGR battery charger and multiple regulators including TPS54318RTER, TPS51211DSCR, TPS51216RUKR, TPS51624RSM, TPS51225RUKR, and UP1658RQKF. Networking is provided by a Realtek RTL8111 LAN IC and a WLAN+BT module. The card reader controller is a GL843L, and the HDMI level shifter is an ITE6513.
Q: What is the BIOS/SPI flash configuration on this motherboard?
A: The BIOS/SPI flash configuration is 8M+4M.
A: The embedded controller is an IT8587.
A: The charging IC is a BQ24737RGR, and the architecture is a battery charger.
A: The memory is dual-channel DDR3L-SODIMM across channels CHA and CHB, supporting 1066/1333/1600 MHz.
| Project Code | ZQ0 |
| Board Number | 3A146 |
| Revision | ZQ0 |
| Date | Monday, April 07, 2014 |
| CPU Platform | BRODWELL ULT 15W |
| GPU Type | iGPU |
| Graphics Architecture | GT3 IMC MCP 1168 pins |
| EC / KBC | IT8587 |
| Audio Codec | ALC283 |
| BIOS / SPI Flash | 8M+4M |
| BIOS Flash Capacity | 8M+4M |
| Charging IC | BQ24737RGR |
| Charger Architecture | Batery Charger |
| Power IC(s) | TPS54318RTER, TPS51211DSCR, TPS51216RUKR, TPS51624RSM, TPS51225RUKR, UP1658RQKF |
| RAM Type | DDR3L-SODIMM |
| RAM Architecture | Dual Channel DDR III |
| RAM Quantity / Slots | CHA, CHB |
| Card Reader IC | GL843L |
| LAN IC | RTL8111 |
| WiFi / WLAN IC | WLAN+BT |
| HDMI Level Shifter | ITE6513 |
ZQ0
3A146
Brodwell ULT
IT8587
ALC283
BQ24737RGR
TPS51211DSCR
TPS51216RUKR
TPS51225RUKR
TPS51624RSM
TPS54318RTER
UP1658RQKF
GL843L
RTL8111
IT6513
ZQ0
3A146
Brodwell ULT
IT8587
ALC283
BQ24737RGR
TPS51211DSCR
TPS51216RUKR
TPS51225RUKR
TPS51624RSM
TPS54318RTER
UP1658RQKF
GL843L
RTL8111
IT6513
