Schematic Acer Aspire A515-44 Quanta ZAUR DAZAURMB8C0 Rev 1A Schematic
BrandQuanta Computer Inc.
Project CodeZAUR
DateTuesday, March 17, 2020
CPU PlatformAMD Renoir Platform
CPU ModelAMD FP6 Renoir
EC / KBCIT8987
Audio CodecALC255-CG
BIOS / SPI FlashSPI ROM
Charging ICBQ24780S
RAM TypeDDR4
RAM ArchitectureOn Board Memory
LAN ICRTL8111HSH-CG
WiFi / WLAN ICWifi / BT M.2
Card Reader ICRTS5441
USB Hub ICPS8409
HDMI Level ShifterSN75LVCP601RTJR
Thermal SensorTMP708AIDBVR
Power IC(s)JW7110DFN, G5334CQT1, TPS51486R, RT6256/6258, RT3662A, JW5222RSOTB, JW5213DFND, G5335QT2, UP8801SSW
dGPU Chip NumberNA
dGPU to UMA Conversion SupportIV@ : UMA
RAM Quantity / SlotsDDR4-Memory Down
Platform AliasZAUR
Document NumberZAUR
Revision1A
GPU TypeIntegrated PCH
Graphics ArchitectureAMD Renoir
EC/KBC PackageKBC IT8987
EC/KBC ProgrammableEmbedded Controller
Charger ArchitectureBQ24780S
Card Reader ICRTS5441+PTN36001
USB Hub ICMUX+Re Driver
The Quanta ZAUR project is an AMD Renoir Platform motherboard built around the AMD FP6 Renoir APU with integrated PCH graphics. The board features an IT8987 embedded controller, an ALC255-CG audio codec, and an RTL8111HSH-CG LAN controller. Memory architecture is DDR4 on-board memory. The charging solution is managed by a BQ24780S battery charger. The system uses an SPI ROM for BIOS storage. The board supports UMA graphics configuration as indicated by the IV@ : UMA BOM option, with no discrete GPU. Power management is handled by a complex array of regulators including JW7110DFN, G5334CQT1, TPS51486R, RT6256/6258, RT3662A, JW5222RSOTB, JW5213DFND, G5335QT2, and UP8801SSW. The design includes a TMP708AIDBVR thermal sensor, an RTS5441+PTN36001 card reader and USB hub combination, and an SN75LVCP601RTJR HDMI level shifter.
Q: What EC/KBC is used on this Quanta ZAUR motherboard?
A: The embedded controller is an IT8987.
A: The battery charger IC is a BQ24780S.
A: Yes, the BOM option IV@ : UMA indicates the board
  • Acer Aspire A515-44 Quanta ZAUR DAZAURMB8C0 Rev 1A Schematic.pdf
