Acer A515-56 FH4AT LA-K091P Schematic
This Compal LA-K091P schematic documents the FH5AT/FH4AT motherboard, built around the Intel Tiger Lake UP3 platform with a 1499-pin BGA processor. The board utilizes a dual-channel DDR4 memory architecture, supporting either a single 260-pin DDR4 SO-DIMM module or onboard DDR4 memory configured as 8GB 1024Mbx16 interleaved or 4GB 512Mbx16. System management is handled by an ENEKB9052 EC/KBC, while the BIOS is stored on a 128Mb SPI ROM. Audio is provided by an ALC255 HDA codec. For connectivity, the board integrates a Realtek 8111H Gigabit LAN controller, an RTS5441 Type-C MUX, and a PS8409DDIA HDMI repeater. Power management and charging are managed by an SLGC55544 charger IC.
A: The board number and project code are both LA-K091P.
A: The EC/KBC is an ENEKB9052.
A: The BIOS is stored on a 128Mb SPI ROM.
Q: What memory configurations are supported?
A: The board supports dual-channel DDR4, configurable as a single 260-pin DDR4 SO-DIMM or onboard 8GB 1024Mbx16 interleaved memory, or onboard 4GB 512Mbx16.
| Model | FH5AT/FH4AT |
| Project Code | LA-K091P |
| Board Number | LA-K091P |
| Revision | 1.B |
| Date | 2020.07.08 |
| CPU Platform | Intel Tiger Lake UP3 |
| EC / KBC | ENEKB9052 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | SPI ROM 128Mb |
| LAN IC | Realtek 8111H |
| RAM Quantity / Slots | 260pin DDR4-SO-DIMM X1 or DDR4-ON BOARD 8G 1024Mbx16 Interleaved Memory or DDR4-ON BOARD 4G 512Mbx16 |
| HDMI Level Shifter | PS8409DDIA |
| USB Hub IC | RTS5441 |
| Charging IC | SLGC55544 |
