acer aspire 5100_5110 compal_la-3151p_rev0.3 schematic
acer aspire 5100_5110=1=compal_la-3151p_rev0.3.pdf
This Compal LA-3151P motherboard, project code HCW50, revision 0.3 for PVT, is built around the AMD Turion/Sempron CPU platform using Socket S1 638P. The chipset consists of an ATI RX485M northbridge paired with an ATI-SB460 southbridge. Graphics are handled by an ATI M52PG/M54P/M56P GPU with 64/128/256MB VRAM. System memory is supported via two DDRII-SO-DIMM slots in a dual-channel DDR-II architecture. The embedded controller is an ENE KB910, and audio is managed by a Realtek ALC883 codec. Networking is provided by a Realtek RTL8100CL LAN IC. The schematic document number is 401412B, dated February 28, 2006.
A: The board number is LA-3151P, and the project code is HCW50.
A: The embedded controller is an ENE KB910.
Q: What is the CPU platform and socket type?
A: The CPU platform is AMD Turion/Sempron, using Socket S1 638P.
Q: What type of memory architecture does this board support?
A: It supports dual-channel DDR-II memory via two DDRII-SO-DIMM slots.
| Project Code | HCW50 |
| Board Number | LA-3151P |
| Revision | 0.3 (For PVT) |
| Date | 2006 / 02 / 28 |
| Document Number | 401412B |
| CPU Platform | AMD Turion/Sempron |
| CPU Socket | Socket S1 638P |
| PCH / Southbridge | ATI-SB460 |
| GPU Type | ATI M52PG/M54P/M56P |
| Graphics Architecture | with 64/128/256MB VRAM |
| EC / KBC | ENE KB910 |
| Audio Codec | ALC883 |
| BIOS / SPI Flash | page 35 |
| Charging IC | page 42 |
| RAM Type | DDRII |
| RAM Architecture | Dual Channel DDR-II |
| RAM Quantity / Slots | DDRII-SO-DIMM X2 |
| Card Reader IC | page 38 |
| USB Hub IC | page 39 |
| LAN IC | Realtek RTL8100CL |
| WiFi / WLAN IC | page 32 |
| HDMI Level Shifter | page 30 |
HCW50
LA-3151P
Sempron
Turion
S1
SB460
M52PG
M54P
M56P
KB910
ALC883
PAGE35
PAGE42
PAGE38
PAGE39
RTL8100CL
page 32
PAGE30
HCW50
LA-3151P
Sempron
Turion
S1
SB460
M52PG
M54P
M56P
KB910
ALC883
PAGE35
PAGE42
PAGE38
PAGE39
RTL8100CL
page 32
PAGE30
