acer as4810_5810 wistron jm41_jm51_dis_08274-1 schematic
jm41_jm51_dis_08274-1.pdf
This Wistron JM41_Discrete-1 motherboard, project code 91.4CQ01.001 with PCB P/N 48.4CQ01.0SB revision 08274-1 dated April 7, 2009, is built around an Intel Cantiga-GS SFF CPU platform paired with an ICH9M SFF southbridge. Graphics are handled by an ATI M92-S2 GPU with switchable graphic capability and 512MB of DDR3 VRAM. The embedded controller is a Winbond WPC E773LA0DG, while the audio subsystem uses a Realtek ALC269Q codec. Networking is provided by an Atheros AR8131 LAN/WLAN IC. The board features a 2MB BIOS flash, DDR3 memory running at 800/1066 MHz, and a comprehensive power delivery system including TPS51125, RT8202, ISL6263A, ADP3207A, and RT9026 regulators. Charging is managed by a MAX8731A IC, and thermal monitoring is handled by an EMC2103 sensor.
A: The embedded controller is a Winbond WPC E773LA0DG.
Q: What BIOS flash capacity is used?
A: The board uses a 2MB BIOS flash.
Q: What GPU is present and does it support switchable graphics?
A: The GPU is an ATI M92-S2 with switchable graphic capability.
Q: What charging IC is used?
A: The charging IC is a MAX8731A.
Q: What LAN/WLAN IC is used?
A: The LAN/WLAN IC is an Atheros AR8131.
| Project Code | 91.4CQ01.001 |
| Board Number | JM41_Discrete-1 |
| Revision | 08274-1 |
| Date | Tuesday, April 07, 2009 |
| CPU Platform | Intel CPU Cantiga-GS SFF |
| PCH / Southbridge | ICH9M SFF |
| GPU Type | ATI M92-S2 |
| Graphics Architecture | Switchable Graphic |
| EC / KBC | WPC E773LA0DG Winbond |
| Audio Codec | Realtek ALC269Q |
| BIOS / SPI Flash | BIOS (2MB) |
| LAN IC | Atheros AR8131 |
| Charging IC | MAX8731A |
| Power IC(s) | TPS51125, RT8202, ISL6263A, ADP3207A, RT9026 |
| RAM Architecture | 800/1066 MHz |
| RAM Quantity / Slots | 64Mbx16x4 (512MB) VRAM (DDR3) |
| Card Reader IC | BD CARDREADER |
| WiFi / WLAN IC | Atheros AR8131 |
| Thermal Sensor | EMC2103 |
| PCB P/N | 48.4CQ01.0SB |
91.4CQ01.001
JM41_DISCRETE-1
Cantiga
ICH9M
M92-S2
Switchable Graphic
WPC E773LA0DG WINBOND
ALC269Q
AR8131
MAX8731A
ADP3207A
ISL6263A
RT8202
RT9026
TPS51125
EMC2103
91.4CQ01.001
JM41_DISCRETE-1
Cantiga
ICH9M
M92-S2
Switchable Graphic
ALC269Q
AR8131
MAX8731A
ADP3207A
ISL6263A
RT8202
RT9026
TPS51125
EMC2103
