Hi this is Yoga 260 Lenovo,Hello, If your Bios IC was damaged, you can buy new one, then program the IC
Send the motherboard model, I'll send the Bios file
The Bios Update doesn't work it giveHi this is Yoga 260 Lenovo,
Product 20FES1VK00
version SDK0J40697
Serial C1KS65V0195
I will buy cheap programmer from Aliexpress
CH341A Modul CH341 24 25 Serie EEPROM-Flash-BIOS-USB Programmierer Modul EEPROM 93CXX/25CXX /24CXX - AliExpress 502
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
is this ok ?
Thanks,
Roee
Ok understand that I solder new empty chip, and reprogram inside laptop, so I need some manager program that allows the programming, do you have it also? or I should have it inside my laptop ?yes I understand you send binary file
But how to program it? - with external programmer or inside laptop ?
If inside laptop how to perform it ?
Thanks,
Roee
Hi,To buy programmer device and Bios IC, it's better to ask your question from this link
Technical Support
Golden premium members can access technical support and discuss their repairing problems and issues with them and get help.dr-bios.com
We don't have Bios update! We send you dump file and you need to open laptop and remove Bios IC, then you should program it
with the file we send.
With external programmeryes I understand you send binary file
Thanks,
Roee
I need motherboard model to send the Bios file.Hi,
Can you send it ?
Thanks,
R
