Xiaomi Inventec R10 6050A3074601-MB-A01 Schematic
This Inventec reference design, project code 1310xxxxx-0-0 revision X01 dated 21-OCT-2002, is built around the AM LAKE Y platform. The embedded controller is an NPCE285UA0DX in an LQFP_128 package. System firmware is stored on an SPI ROM. The charging subsystem is managed by a TI_BQ24780S in a QFN_28 package, supporting an IDCHG architecture. Memory consists of LPDDR3 running at 1.2V/0.6V and 1866MHZ. The audio codec is an ALC233. The design incorporates an RTS5450/PS8743 for LAN, card reader, and USB hub functions, along with WLAN/BT connectivity. An LCM W INBOND component is used for HDMI level shifting.
A: The EC/KBC is an NPCE285UA0DX in an LQFP_128 package.
A: The charging IC is a TI_BQ24780S in a QFN_28 package.
Q: What type of memory does this motherboard use?
A: This motherboard uses LPDDR3 memory at 1.2V/0.6V and 1866MHZ.
A: The audio codec is an ALC233.
| Brand | INVENTEC |
| Motherboard Manufacturer | INVENTEC CORPORATION |
| Revision | X01 |
| Date | 21-OCT-2002 |
| CPU Platform | AM LAKE Y |
| EC / KBC | NPCE285UA0DX_LQFP_128 |
| EC/KBC Package | LQFP_128 |
| Audio Codec | ALC233 |
| Charging IC | TI_BQ24780S_QFN_28 |
| Charger Architecture | IDCHG |
| RAM Type | LPDDR3 |
| RAM Architecture | 1.2V / 0.6V 1866MHZ |
| LAN IC | RTS5450/PS8743 |
| WiFi / WLAN IC | WLAN /BT |
| HDMI Level Shifter | LCM W INBOND |
| Card Reader IC | RTS5450/PS8743 |
| USB Hub IC | RTS5450/PS8743 |
| Document Number | 218 FF8 |
