toshiba satellite m305_m335 quanta_te1m_rev e3d schematic
toshiba satellite m305_m335=1=quanta_te1m_rev e3d.pdf
This Quanta Computer Inc. Project E3D motherboard, documented under Document Number 140 dated Monday, May 26, 2008, is built around the Intel PENRYN CPU platform and Intel I/O Controller Hub 9 southbridge. The system memory architecture consists of dual-channel DDRII across two SODIMM slots. The embedded controller is a WPC8763LDG, and the audio subsystem is handled by a CX20561-12Z codec. The BIOS SPI flash is a W25X16VSS1G. Power management is managed by a suite of regulators including ISL88731, ISL6237, ISL6266, ART8202, TPS51116, APL5913, and G909. Networking is provided by an RTL8111C LAN IC and an AR5B91 WLAN module. The board also integrates an R5C847 card reader controller, a GL850G USB hub IC, and a PI3VDP411LST HDMI level shifter.
A: The BIOS SPI flash is a W25X16VSS1G.
A: The embedded controller is a WPC8763LDG.
A: The board supports dual-channel DDRII memory across two SODIMM slots.
| Project Code | E3D |
| Document Number | 140 |
| Date | Monday, May 26, 2008 |
| CPU Platform | PENRYN |
| PCH / Southbridge | Intel I/O Controller Hub 9 |
| EC / KBC | WPC8763LDG |
| Audio Codec | CX20561-12Z |
| BIOS / SPI Flash | W25X16VSS1G |
| Charging IC | ISL88731 |
| Power IC(s) | ISL6237, ISL6266, ART8202, TPS51116, APL5913, G909 |
| RAM Type | DDRII |
| LAN IC | RTL8111C |
| WiFi / WLAN IC | AR5B91 |
| Card Reader IC | R5C847 |
| USB Hub IC | GL850G |
| HDMI Level Shifter | PI3VDP411LST |
E3D
Penryn
I/O 9
WPC8763LDG
CX20561-12Z
W25X16VSS1G
ISL88731
APL5913
ART8202
ISL6237
ISL6266
TPS51116
RTL8111C
AR5B91
R5C847
GL850G
PI3VDP411LST
E3D
Penryn
I/O 9
WPC8763LDG
CX20561-12Z
W25X16VSS1G
ISL88731
APL5913
ART8202
ISL6237
ISL6266
TPS51116
RTL8111C
AR5B91
R5C847
GL850G
PI3VDP411LST
