toshiba satellite l300 inventec pt10sc 6050a2170201-mb-a03 schematic
toshiba satellite l300=1=inventec pt10sc 6050a2170201-mb-a03.pdf
This Inventec IEC951098X01 motherboard, revision 5, dated 29-Nov-2007, is designed for the X01 Model_No 163A3CS PT10SC platform. The board is built around an Intel Merom CPU platform paired with an ICH8-M southbridge and Crestline graphics. System memory consists of two DDR2 SODIMM slots supporting 533/667 MHz interfaces. The embedded controller is a Winbond W775L, and the audio subsystem is handled by a Realtek ALC 268 codec. Power management is provided by a TI TPS51125 QFN-24P system power IC and a TI BQ24721C QFN-32P battery charger. The board utilizes an SPI EEROM for BIOS storage. Networking is supported by a Realtek RTL8102E LAN controller, and a Ricoh R5C804 card reader is present. HDMI output is managed by a Silicon Image SIL1392 transmitter.
A: The embedded controller is a Winbond W775L.
A: The charging IC is a TI BQ24721C in a QFN-32 package.
Q: What type of BIOS flash is used on this motherboard?
A: The board uses an SPI EEROM for BIOS storage.
A: The board supports two DDR2 SODIMM slots with a 533/667 MHz interface.
| Brand | Inventec |
| Model | X01 Model_No 163A3CS PT10SC |
| Project Code | IEC951098X01 |
| Board Number | IEC951098 |
| Revision | 5 |
| Date | 29-Nov-2007 |
| CPU Platform | Merom |
| GPU Type | Crestline |
| EC / KBC | WINBOND W775L |
| Audio Codec | ALC 268 |
| BIOS / SPI Flash | SPI EEROM |
| Charging IC | TI_BQ24721C_QFN_32P |
| Power IC(s) | TI_TPS51125_QFN_24P |
| RAM Type | DDR2 |
| RAM Architecture | DDR2_SODIMM0, DDR2_SODIMM1 |
| Card Reader IC | RICOH R5C804 |
| LAN IC | RTL8102E |
| WiFi / WLAN IC | Realtek |
| HDMI Level Shifter | SIL1392 |
IEC951098X01
IEC951098
Merom
ICH8
Crestline
W775L
ALC268
BQ24721C_QFN_32P
TPS51125_QFN_24P
RICOH_R5C804
RTL8102E
SIL1392
IEC951098X01
IEC951098
Merom
ICH8
Crestline
W775L
ALC268
BQ24721C_QFN_32P
TPS51125_QFN_24P
RICOH_R5C804
RTL8102E
SIL1392
