toshiba satellite l200 inventec miami 10 6050a2110801 schematic
toshiba satellite l200=1=inventec miami 10 6050a2110801.pdf
The Inventec Miami 10 motherboard, documented under board number CSA359 revision 3, is built around the Intel Merom CPU platform paired with the Calistoga northbridge and ICH8-M southbridge. Memory architecture consists of two DDR2 SODIMM slots supporting 533/667 MHz interfaces. System power management is handled by a TI TPS51020DBT power IC in a TSSOP-30 package, while battery charging is controlled by a TI BQ24721 QFN-32 charger IC. The embedded controller and Super I/O functions are integrated into a Winbond W8769L device. Audio is provided by a Realtek ALC268 codec, and networking includes a Marvell 88E8039 LAN controller alongside a Marvell 88W8686 WLAN module. A TI PCI8412 card reader controller and an ICS9LPRS365 clock generator complete the core chipset configuration. The board also features an Express Card slot, CardBus controller, and multiple USB and PCI Express interfaces.
A: The embedded controller and Super I/O are integrated into a Winbond W8769L device.
A: The battery charging controller is a TI BQ24721 in a QFN-32 package.
Q: What power IC manages the system power rails?
A: The system power is managed by a TI TPS51020DBT in a TSSOP-30 package.
Q: What memory configuration does this motherboard support?
A: The board supports two DDR2 SODIMM slots with a 533/667 MHz interface.
| Brand | Inventec |
| Model | Miami 10 |
| Project Code | Miami 10 |
| Board Number | CSA359 |
| Revision | 3 |
| Date | 27-Mar-2007 |
| Document Number | 1310A21108A04 |
| CPU Platform | Merom |
| GPU Type | Calistoga |
| Graphics Architecture | Calistoga |
| EC / KBC | W8769L |
| Audio Codec | ALC268 |
| Charging IC | TI_BQ24721_QFN_32 |
| Power IC(s) | TI_TPS51020DBT_TSSOP_30P |
| RAM Type | DDR2 |
| RAM Architecture | DDR2_SODIMM |
| Card Reader IC | TI PCI8412 |
| LAN IC | Marvell 88E8039 |
| WiFi / WLAN IC | Marvell 88W8686 |
| Clock Generator | ICS9LPRS365 |
| Super I/O | W8769L |
CSA359
Merom
ICH8
Calistoga
W8769L
ALC268
BQ24721_QFN_32
PCI8412
88E8039
88W8686
ICS9LPRS365
W8769L
Super I/O
CSA359
Merom
ICH8
Calistoga
W8769L
ALC268
BQ24721_QFN_32
PCI8412
88E8039
88W8686
ICS9LPRS365
W8769L
Super I/O
