toshiba m50 haz00 htw01 la-2861 rc460 sb450 401369-a 0815 rev a
This Compal LA-2861 motherboard schematic, revision 1.0 dated 2005-07-11, documents a platform built around the UFC-PGA Dothan CPU and ATI-RC410MB graphics with M10P embedded architecture, paired with an ATI-SB450 southbridge. The system utilizes an ENE KB910 embedded controller and an ALC 250 audio codec. Memory configuration consists of two SO-DIMM slots for DDRII RAM. The board features a 1M BIOS flash, an ICS951411AG clock generator, and an ADM1032 thermal sensor. Integrated peripherals include an RTL8100CL LAN controller, a CB1410 card reader, a TSB43AB21 FireWire controller, a TI 1410 CardBus controller, and an APA2068 audio amplifier. The charging circuit is managed by a dedicated CHARGER IC.
Q: What embedded controller is used on this Compal LA-2861 motherboard?
A: The embedded controller is an ENE KB910.
A: The BIOS flash is specified as 1M.
A: The memory architecture is DDRII, using two SO-DIMM slots.
Q: What audio codec and LAN controller are integrated on this board?
A: The audio codec is an ALC 250, and the LAN controller is an RTL8100CL.
| Model | LA-2861 |
| Board Number | LA-2861 |
| Date | 2005-07-11 |
| Document Number | 401369A |
| CPU Platform | UFC-PGA Dothan |
| PCH / Southbridge | ATI-SB450 |
| GPU Type | ATI-RC410MB |
| Graphics Architecture | M10P Embeded |
| EC / KBC | ENE KB910 |
| Audio Codec | ALC 250 |
| BIOS / SPI Flash | BIOS(1M) |
| Charging IC | CHARGER |
| RAM Type | DDRII |
| RAM Architecture | SO-DIMM x 2 |
| Thermal Sensor | ADM1032 |
| Card Reader IC | CB1410 |
| LAN IC | RTL8100CL |
| WiFi / WLAN IC | Mini-PCI(WLAN) |
| Audio Amplifier | APA2068 |
| Clock Generator | ICS951411AG |
| FireWire Controller | TSB43AB21 |
| CardBus Controller | TI 1410 |
LA-2861
Dothan
SB450
RC410MB
M10P Embeded
KB910
ALC250
ADM1032
CB1410
RTL8100CL
APA2068
ICS951411AG
TSB43AB21
Bridge / Expander
LA-2861
Dothan
SB450
RC410MB
M10P Embeded
KB910
ALC250
ADM1032
CB1410
RTL8100CL
APA2068
ICS951411AG
TSB43AB21
Bridge / Expander
