Schematic sony vaio pcg-k13 quanta je2.1 rev1a mbx-114 schematic
sony vaio pcg-k13 quanta_je2.1_rev1a_mbx-114 schematic
sony vaio pcg-k13=1=quanta_je2.1_rev1a_mbx-114.pdf
BrandQUANTA COMPUTER
ModelJE2.1 Main Board
Motherboard ManufacturerQUANTA COMPUTER
Board NumberJE2.1 Main Board
Revision1A138
DateWednesday, July 09, 2003
CPU PlatformIntel Pentium 4 75W
CPU Socket478 PIN mPGA
PCH / SouthbridgeALI 1535+
NorthbridgeATI RS200M
GPU TypeATI RADEON 9200 ([URL="https://dr-bios.com/components/graphics-models/m9-x/"]M9+X)[/URL]
dGPU Chip NumberATI M9+
Graphics ArchitectureAGP bus
EC / KBCNS PC87570
Audio CodecALC203
BIOS / SPI FlashBIOS
Charging ICMAX1632
Power IC(s)MAX1546, MAX1844
RAM TypeDDR 266
RAM ArchitectureSO-DIMM 1/2
RAM Quantity / Slots2
Card Reader ICTI-PCI7420
USB Hub ICNEC uPD720101
LAN ICRTL8100B
WiFi / WLAN ICWirless LAN Mini PCI
RTCTIBQ3285LF
The Quanta JE2.1 Main Board (Revision 1A138, dated July 9, 2003) is built around an Intel Pentium 4 75W CPU in a 478-pin mPGA socket, paired with an ATI RS200M Northbridge and an ALI 1535+ Southbridge. Graphics are handled by an ATI Radeon 9200 (M9+X) GPU with 16MB x4 DDR VRAM, connected via the AGP bus. The system uses DDR 266 memory across two SO-DIMM slots. The embedded controller is an NS PC87570, and the audio codec is an ALC203. Power management is handled by MAX1632, MAX1546, and MAX1844 ICs. Networking is provided by a Realtek RTL8100B LAN controller, and USB 2.0 connectivity is managed by a NEC uPD720101 controller. The board also features a TI PCI7420 card reader and a TIBQ3285LF RTC.
A: The board is the Quanta JE2.1 Main Board, Revision 1A138.
A: The embedded controller is an NS PC87570.
Q: What is the CPU platform and socket type?
A: The CPU platform is an Intel Pentium 4 75W, using a 478-pin mPGA socket.
Q: What is the graphics architecture and GPU model?
A: The graphics architecture is AGP bus, using an ATI Radeon 9200 (M9+X) GPU with 16MB x4 DDR VRAM.
Q: What LAN and USB controllers are used?
A: The LAN controller is a Realtek RTL8100B, and the USB 2.0 controller is a NEC uPD720101.
  • Sony Vaio PCG-K13=1=quanta_JE2.1_Rev1A_MBX-114.zip
