Schematic otherbrand intel 440lx rev1.4 schematic
otherbrand intel 440lx_rev1.4 schematic
otherbrand=1=intel 440lx_rev1.4.pdf
BrandIntel
Motherboard ManufacturerIntel Corporation
Project Code440LX CUSTOMER REFERENCE DESIGN
Board Number440LX PCIset
Revision1.4
DateThursday, May 07, 1998
CPU PlatformSlot 1
PCH / Southbridge82371AB (PIIX4)
GPU Type82443LX ([URL="https://dr-bios.com/components/graphics-models/agp/"]AGP)[/URL]
Graphics ArchitectureAGP
RAM TypeDIMM
RAM ArchitectureSDRAM
RAM Quantity / Slots3 DIMM
BIOS / SPI FlashFLASH BIOS
LAN ICUltra I/O
WiFi / WLAN ICSerial/Flopy
This Intel 440LX Customer Reference Design, revision 1.4, dated May 7, 1998, is a Slot 1 platform built around the 82443LX AGP memory controller hub and the 82371AB PIIX4 southbridge. The board supports three DIMM sockets for SDRAM memory and features an AGP graphics architecture. Storage connectivity is provided by primary and secondary IDE connectors, while the system includes a Flash BIOS, an Ultra I/O controller, and serial/floppy interfaces. The design incorporates a VRM for voltage regulation and GTL termination for the host bus. The block diagram illustrates the interconnection between the host bus, PCI bus, ISA bus, and AGP sideband signals.
Q: What is the board number and revision of this Intel reference design?
A: The board is the Intel 440LX PCIset, revision 1.4.
Q: What CPU socket does this motherboard use?
A: This motherboard uses a Slot 1 connector for the CPU.
Q: What is the memory architecture and how many DIMM slots are available?
A: The board supports SDRAM memory via three DIMM sockets.
Q: What are the primary chipset components on this motherboard?
A: The chipset consists of the 82443LX AGP memory controller hub and the 82371AB PIIX4 southbridge.
  • otherbrand=1=Intel 440LX_Rev1.4.zip
