Schematic MSI MS-9188 Rev 00a 11 100 Schematic
BrandMSI (Micro-Star Int'l Co., Ltd.)
ModelMS-9188
Motherboard ManufacturerMicro-Star Int'l Co., Ltd.
Document NumberMS-9188
Revision00A
DateThursday, October 05, 2006
CPU PlatformDual Intel FC-LGA4 771 Dempsey / Woodcrest / Clovertown
PCH / SouthbridgeIntel 632xESB
GPU Typevolari-z7/"]XGI Volari Z7[/URL]
EC / KBCWinbond W83627EHG
Audio CodecNot explicitly present in source
Charging ICNot explicitly present in source
RAM TypeDDR2 FBDIMM
RAM Architecture2 Branch / 4 Channel
RAM Quantity / Slots8
LAN ICIntel 82571EB
WiFi / WLAN ICNot explicitly present in source
Card Reader ICNot explicitly present in source
USB Hub ICNot explicitly present in source
HDMI Level ShifterNot explicitly present in source
Power IC(s)VT1115M
Charger ArchitectureNot explicitly present in source
Thermal SensorWinbond W83793G
BIOS / SPI FlashNot explicitly present in source
EC Flash / ROMNot explicitly present in source
Super I/OWinbond W83627EHG
IPMI ControllerHITACHI H8S/2168
Form Factor8 Layer E-ATX (W 394mm X L 330mm)
The MSI MS-9188 Rev 00A is a dual-socket server motherboard built on the Intel 5000P / 632xESB chipset, supporting Intel FC-LGA4 771 Dempsey, Woodcrest, and Clovertown processors. Memory architecture consists of 8 DDR2 FBDIMM slots configured across 2 branches and 4 channels. Graphics are handled by an XGI Volari Z7 GPU. The platform integrates dual Intel 82571EB LAN controllers with bypass functionality, a Winbond W83627EHG Super I/O and EC/KBC, and a VT1115M 5-phase PWM VRD 11 voltage regulator. System management is provided by a HITACHI H8S/2168 IPMI controller, and thermal monitoring is managed by a Winbond W83793G sensor. The board is an 8-layer E-ATX form factor measuring 394mm by 330mm.
A: The board number is MS-9188, revision 00A, dated October 5, 2006.
Q: What CPU platform does the MS-9188 support?
A: It supports dual Intel FC-LGA4 771 Dempsey, Woodcrest, and Clovertown processors.
Q: What memory architecture is used on the MS-9188?
A: The board uses 8 DDR2 FBDIMM slots configured in a 2-branch, 4-channel architecture.
Q: What LAN controllers are present on this motherboard?
A: The board uses dual Intel 82571EB LAN controllers with bypass functionality.
Q: What EC/KBC and Super I/O controller is used?
A: The board uses a Winbond W83627EH
ModelMS-9188
Revision100
DateThursday, January 11, 2007
PCH / Southbridge632xESB
GPU Typez7/"]XGI Z7[/URL] / Volari Z7
Audio CodecWinbond W83793G
Charging ICVT1115M
Power IC(s)VT1115M
RAM TypeDDR2 FBDIMM
LAN IC82571EB
WiFi / WLAN IC82571EB
Card Reader ICH8S/2168
USB Hub ICVT1115M
The MSI MS-9188 Rev100 is a dual-socket server motherboard built around the Intel 5000P and 632xESB chipset, supporting Dempsey, Woodcrest, and Clovertown processors in FC-LGA4 771 packages. Memory architecture consists of eight DDR2 FBDIMM slots configured across two branches and four channels. Graphics are handled by an XGI Z7 or Volari Z7 GPU. The system integrates a Winbond W83627EHG Super I/O and a Winbond W83793G hardware monitor. Power regulation is managed by VT1115M controllers in a VRD 11 5-phase PWM configuration. Networking is provided by Intel 82571EB controllers supporting RJ45 and SFP ports with bypass functionality. IPMI management is handled by a Hitachi H8S/2168 BMC. The board also includes a Compact Flash connector, PCI-X slots, and a proprietary PCI Express x16 slot.
A: The board number is MS-9188, revision 100.
Q: What memory architecture is used on this board?
A: The board uses eight DDR2 FBDIMM slots configured in a 2 Branch / 4 Channel architecture.
Q: What EC/KBC is used on the MS-9188?
A: The EC/KBC is a Winbond W83627EHG Super I/O.
A: The board uses Intel 82571EB controllers for RJ45 and SFP ports with bypass functionality.
BrandMicro-Star Int'l Co., Ltd.
ModelMS-9188
Board NumberMS-9188
RevisionRev11
DateThursday, March 15, 2007
EC / KBCHITACHI H8S/2168
BIOS / SPI FlashFWH
RAM TypeDDR2 FBDIMM
RAM Quantity / Slots8 DDR2 FBDIMM
LAN ICIntel 82571EB
WiFi / WLAN ICGilgal PHY
Card Reader ICCompact Flash
USB Hub ICUSB 2.0
Charging ICvt1115m/"]VRD 11 VT1115M[/URL]
Power IC(s)VT1115M, VT1115S
IPMIHITACHI H8S/2168
The Micro-Star MS-9188 Rev11 is a dual-socket server motherboard built on the Intel 5000P / 632xESB chipset, supporting Intel FC-LGA4 771 Dempsey, Woodcrest, and Clovertown processors. Memory architecture consists of 8 DDR2 FBDIMM slots configured across 2 branches and 4 channels. Graphics are handled by an XGI Z7 / Volari Z7 GPU. The system incorporates a Winbond W83627EHG Super I/O, a Winbond W83793G hardware monitor and audio codec, and an HITACHI H8S/2168 IPMI controller. Networking is provided by multiple Intel 82571EB controllers with Gilgal PHY interfaces, supporting bypass functionality. Storage includes SATA 3.0Gb/s, Ultra DMA 66/100, and Compact Flash support. Power delivery uses VRD 11 VT1115M 5-Phase PWM controllers. The board is an 8-layer E-ATX form factor measuring 394mm by 330mm.
A: The board number is MS-9188, revision Rev11.
Q: What CPU platform does this motherboard support?
Q: What IPMI controller is used on this motherboard?
A: The IPMI controller is an HITACHI H8S/2168.
A: It supports 8 DDR2 FBDIMM modules configured in 2 branches and 4 channels.
Q: What LAN controllers are used on this motherboard?
A: Multiple Intel 82571EB controllers with Gilgal PHY interfaces are used, supporting bypass functionality.
  • MSI MS-9188 Rev 00a-1005 Schematic.pdf
  • MSI MS-9188 Rev 11 Schematic.pdf
  • MSI MS-9188 Rev 100-0111 Schematic.pdf
