msi ms-5510 55151 rev 0a
This MSI MS-5510 motherboard, board number MS-55151 revision 0A, is based on the SigmalTel 3410 platform. The system is powered by an STMP3410 EC/KBC and utilizes an LTC3406 charging IC and power IC. Memory architecture is NAND Flash based. The board integrates FM tuner, LCD display, USB and audio interfaces, and key button controls. The power tree includes +1.8V VDDD, +3.3V VDDIO, and +3.3V VDDIO_P rails.
A: The board number is MS-55151, revision 0A.
A: The EC/KBC is the STMP3410.
A: The charging IC is the LTC3406.
| Brand | MSI |
| Model | MS-5510 |
| Motherboard Manufacturer | MSI |
| Project Code | MS-5510 |
| Board Number | MS-55151 |
| Revision | 0A |
| Date | 星期一, 九月 15, 2003 |
| CPU Platform | SigmalTel 3410 |
| EC / KBC | STMP3410 |
| Charging IC | LTC3406 |
| Power IC(s) | LTC3406 |
| RAM Type | NAND Flash |
| RAM Architecture | NAND Flash |
