msi ms-1682_rev0b schematic
msi=1=ms-1682_rev0b.pdf
This MSI MS-1682 motherboard, documented under MS-16820A revision 0B, is built around an Intel Penryn CPU platform paired with a SIS968 southbridge and M672DX northbridge architecture. Graphics are handled by an M92M GPU. The system uses an ENE3925 EC/KBC controller and an SPI BIOS flash. Audio is provided by a Realtek ALC662 codec. Memory configuration consists of two single-channel DDRII SODIMM slots. Power management is handled by a combination of TPS51117, TPS51125, ISL6262A, APL5915, APL5331, and SC339 regulators, with battery charging managed by a MAX8724 IC. Networking is supported by a Realtek RTL8201CL PHY-LAN controller, and a RTS5158E card reader IC is present.
Q: What EC/KBC controller is used on this MSI MS-1682 motherboard?
A: The motherboard uses an ENE3925 EC/KBC controller.
Q: What audio codec is present on this motherboard?
A: The audio codec is a Realtek ALC662.
A: This motherboard supports single-channel DDRII memory via two SODIMM slots.
A: The charging IC is a MAX8724.
| Brand | MSI |
| Model | MS-1682 |
| Motherboard Manufacturer | MSI CORPORATION |
| Board Number | MS-1682 |
| Revision | 0B |
| Date | Wednesday, January 21, 2009 |
| Document Number | MS-16820A |
| CPU Platform | Penryn |
| PCH / Southbridge | SIS968 |
| GPU Type | M92M |
| Graphics Architecture | M672DX |
| EC / KBC | ENE3925 |
| Audio Codec | ALC662 |
| BIOS / SPI Flash | SPI |
| Charging IC | MAX8724 |
| Power IC(s) | TPS51117, TPS51125, ISL6262A, APL5915, APL5331, SC339 |
| RAM Type | DDRII |
| Card Reader IC | RTS5158E |
| LAN IC | RTL8201CL |
MS-1682
Penryn
SIS968
M92M
M672DX
ENE3925
ALC662
MAX8724
APL5331
APL5915
ISL6262A
SC339
TPS51117
TPS51125
RTS5158E
RTL8201CL
MS-1682
Penryn
SIS968
M92M
M672DX
ENE3925
ALC662
MAX8724
APL5331
APL5915
ISL6262A
SC339
TPS51117
TPS51125
RTS5158E
RTL8201CL
