msi ms-1313 2007 rev 0a
This MSI MS-1331 motherboard, revision 0A, dated 2007/5/29, is built around the Intel Penryn CPU platform with an Intel Cantiga GMCH northbridge and ICH8M southbridge. The system memory architecture consists of dual-channel DDRII 533/667 MHz across two SODIMM slots. The embedded controller is an ENE 3925. For networking, a Realtek RTL8111C Gigabit LAN controller is used, while audio is handled by an ALC888 codec. The board features a Realtek RTS5158E card reader IC and a MAX 8724 wireless module. Power management is distributed across multiple ICs including the TPS51120, TPS51124, TPS51117, and ISL6262A, with charging controlled by an ISL6263. The HDMI interface utilizes an ITPM 1.2 level shifter, and thermal monitoring is provided by an RT9173 sensor. The schematic document number is MS-13310A.
A: The board number is MS-1331, revision 0A.
A: The embedded controller is an ENE 3925.
A: The memory architecture is dual-channel DDRII 533/667 MHz with two SODIMM slots.
A: The charging IC is an ISL6263.
| Brand | MSI |
| Model | MS-1331 |
| Board Number | MS-1331 |
| Revision | 0A |
| Date | 2007/5/29 |
| CPU Platform | Intel Penryn |
| Northbridge | Intel Cantiga GMCH |
| Southbridge | ICH8M |
| EC / KBC | ENE 3925 |
| RAM Type | DDRII |
| LAN IC | RTL8111C |
| Card Reader IC | RTS5158E |
| Charging IC | ISL6263 |
| Power IC(s) | TPS51120, TPS51124, TPS51117, ISL6262A |
| Audio Codec | ALC888 |
| WiFi / WLAN IC | MAX 8724 |
| HDMI Level Shifter | ITPM 1.2 |
| Thermal Sensor | RT9173 |
| Document Number | MS-13310A |
MS-1331
Penryn
ICH8M
3925
RTL8111C
RTS5158E
ISL6263
ISL6262A
TPS51117
TPS51120
TPS51124
ALC888
MAX 8724
ITPM 1.2
RT9173
MS-1331
Penryn
ICH8M
3925
RTL8111C
RTS5158E
ISL6263
ISL6262A
TPS51117
TPS51120
TPS51124
ALC888
MAX 8724
ITPM 1.2
RT9173
