Schematic MSI MC871 MS-9154-040 Rev A00 110 10A Schematic
BrandDell
Motherboard ManufacturerDell Computer Corporation
Project Code2800/2850/1850
Board NumberP# W7747
Revisiona00
Date11/19/2004
CPU PlatformProcessors
GPU TypeRadeon Video
Graphics ArchitectureRadeon Video
RAM TypeDDR2
RAM ArchitectureDDR2
LAN ICGigabit Ethernet
WiFi / WLAN ICGigabit Ethernet
PCH / SouthbridgeICH5
Super I/OSuper I/O, 373
BMCBMC
System CPLDSystem CPLD
Clock Synth.Clock Synth.
Differential BufferDifferential Buffer DB800
FWHFWH
PXHPXH
VRDVRD
Voltage RegulatorsVoltage Regulators
Fan PWM ControllersFan PWM Controllers
Battery / Intrusion Detect / RAID Key / VAux PwrgoodBattery / Intrusion Detect / RAID Key / VAux Pwrgood
Fans and fan LED'sFans and fan LED's
Parallel Port / ID Button / Rear Cyclops / SpeakerParallel Port / ID Button / Rear Cyclops / Speaker
Keyboard, Mouse, COM Ports, I2C MUX/TableKeyboard, Mouse, COM Ports, I2C MUX/Table
USB / ButtonsUSB / Buttons
PCI bus p/u's / PCI Debug SlotPCI bus p/u's / PCI Debug Slot
Debug FeaturesDebug Features
ITP 32 & Level Translation CircuitsITP 32 & Level Translation Circuits
BMC - Serial Port MUXing DiagramBMC - Serial Port MUXing Diagram
BMC, Serial Port MuxingBMC, Serial Port Muxing
1.2V Vtt generation1.2V Vtt generation
VAux resetVAux reset
Decoupling CapsDecoupling Caps
DDR2, routing diagramDDR2, routing diagram
DDR2, VRefDDR2, VRef
MCH, memoryMCH, memory
MCH, GTL, Exp, Hub-linkMCH, GTL, Exp, Hub-link
MCH, powerMCH, power
ProcessorsProcessors
VRDVRD
BrandDell
ModelPowerEdge 2800/2850/1850
Motherboard ManufacturerDell Inc.
Board NumberD1660
RevisionA03-00
Date12/16/2004
PCH / SouthbridgeICH5R
RAM TypeDDR2
RAM Quantity / SlotsDDR2
Charging ICBattery / Intrusion Detect / RAID Key / VAux Pwrgood
Power IC(s)Voltage Regulators VRD
Thermal SensorFans and fan LED's
Card Reader ICSD Card
USB Hub ICUSB / Buttons
WiFi / WLAN ICWireless
HDMI Level ShifterHDMI
Audio CodecAudio
EC / KBCBMC
EC/KBC ProgrammableBMC
BIOS / SPI FlashFWH
BIOS Flash PackageFWH
EC Flash / ROMBMC
Charger ArchitectureBattery / Intrusion Detect / RAID Key / VAux Pwrgood
Drawing NumberD1660
Document NumberD1660
Platform AliasLINDY PLANARD
CPU SocketProcessors
dGPU Chip NumberRadeon Video
dGPU to UMA Conversion SupportRadeon Video
Compatible BIOS IC ModelsFWH
Clock GeneratorClock Synth.
Fan ControllerFan PWM Controllers
Serial PortSerial Port MUXing Diagram
Parallel PortParallel Port / ID Button / Rear Cyclops / Speaker
KeyboardKeyboard, Mouse, COM Ports, I2C MUX/Table
MouseKeyboard, Mouse, COM Ports, I2C MUX/Table
ITPITP 32 & Level Translation Circuits
PCI BusPCI bus p/u's / PCI Debug Slot
Battery
BrandDell
ModelPE2800/2850/1850
Board NumberMC871
RevisionA00
Date08/12/2005
RAM TypeDDR2
BMCBMC
FWHFWH
PWA Assembly1U PWA assembly
PWA Assembly (Alt)2U/5U PWA assembly
Drawing Number123BD
Document NumberMC871
PWA NumberPWA,PLN,SV,DELL,PE2800/2850/1850
Project CodeTrio MLK2 Planar
PWB/Silk ColorRed
This Dell PowerEdge 2800/2850/1850 server planar, designated MC871 revision A00 dated August 12, 2005, is built around an Intel ICH5R southbridge and supports DDR2 memory. The platform utilizes Radeon Video graphics and Gigabit Ethernet connectivity. The board is managed by a BMC (Baseboard Management Controller) and includes a System CPLD for logic integration. Clock generation is handled by a Clock Synth. and a Differential Buffer DB800. The firmware hub (FWH) is present for BIOS storage. The planar supports multiple chassis configurations with separate 1U and 2U/5U PWA assembly variants. The project code is Trio MLK2 Planar, and the PWB silk color is Red.
Q: What is the board number and revision for this Dell server planar?
A: The board number is MC871, revision A00, dated 08/12/2005.
Q: What southbridge is used on this Dell PowerEdge planar?
A: The southbridge is an Intel ICH5R.
Q: What type of memory does this planar support?
A: This planar supports DDR2 memory.
Q: What management controller is present on this board?
A: A BMC (Baseboard Management Controller) is present.
BrandDell
Board NumberD1660
RevisionA02-00
Date10/21/2004
RAM TypeDDR2
BMCBMC
Voltage RegulatorsVRD
Fan ControllersFan PWM Controllers
PWA NumberH1754
PWA Assembly NumberP# H1754
PWA Assembly Number (1U)1U PWA assembly
PWA Assembly Number (2U/5U)2U/5U PWA assembly
PWA Assembly Number (Spares)P# D8266
PWB NumberPWB:
Schematic NumberSCHEM:
Assembly Drawing NumberASSY DWG:
Drawing NumberD1660
Platform AliasBig Bend, Kobuk, Corvette
Memory Controller HubMCH, memory
PCI Express HubPXH
Firmware HubFWH
ITP ConnectorITP 32 & Level Translation Circuits
BatteryBattery / Intrusion Detect / RAID Key / VAux Pwrgood
USBUSB / Buttons
FansFans and fan LED's
BOM Build OptionsBOM Build option table
BOM Build Options (1U)1U, Production
BOM Build Options (2U/5U)2U/5U Production
PWB/Silk Color (Red)Red
PWB/Silk Color (White)
BrandDell
Board NumberLINDY PLANAR
Revisiona00
Date11/19/2004
CPU PlatformXeon ([URL="https://dr-bios.com/components/cpu-platform/big-bend/"]Big Bend[/URL], Kobuk, Corvette)
RAM TypeDDR2
EC / KBCBMC
Audio CodecAC97
Charging ICBMC
Charger ArchitectureBMC
Power IC(s)VRD
Card Reader ICSuper I/O
USB Hub ICICH5
HDMI Level ShifterRadeon Video
Thermal SensorBMC
Document NumberC8358
Drawing Number123BD
Project CodePE2800/2850/1850
This Dell Computer Corporation schematic, dated 11/19/2004, documents the LINDY PLANAR motherboard (revision a00) for the PE2800/2850/1850 server platform. The board is built around the Xeon processor family (Big Bend, Kobuk, Corvette) with an ICH5R southbridge and Radeon Video graphics. Memory architecture is DDR2, supported by VRD voltage regulators. The system integrates Gigabit Ethernet, AC97 audio, and a Super I/O controller. The BMC (Baseboard Management Controller) handles EC/KBC functions, thermal monitoring, and charging architecture. The drawing number is 123BD, and the document number is C8358.
Q: What is the board number and revision for this Dell server motherboard?
A: The board is identified as LINDY PLANAR, revision a00.
Q: What processor platform does this motherboard support?
A: This motherboard supports the Xeon processor family, specifically the Big Bend, Kobuk, and Corvette platforms.
Q: What type of memory architecture is used on this board?
A: The memory architecture is DDR2.
Q: What is the EC/KBC controller on this motherboard?
A: The EC/KBC functions are handled by the BMC (Baseboard Management Controller).
A: The document number is C8358.
BrandDell
ModelPowerEdge 2800/2850, 1850
Motherboard ManufacturerDell Computer Corp.
Project CodeTRIO MLK PLANAR
Board NumberC8358
RevisionA00-001
Date12/20/2004
PCH / SouthbridgeICH5, ICH5R
EC / KBCBMC
RAM TypeDDR2
Charger ArchitectureVRD
Power IC(s)Voltage Regulators, VRD
Thermal SensorMicroVu
MCHMCH, memory, MCH, GTL, Exp, Hub-link, MCH, power
PXHPXH
FWHFWH
Drawing Number123BD
This Dell PowerEdge 2800/2850, 1850 server planar, project code TRIO MLK PLANAR, board number C8358 revision A00-001 dated 12/20/2004, is built around a dual-processor architecture with ICH5/ICH5R southbridge and MCH memory controller hub. Graphics are handled by Radeon Video. System management is provided by a BMC controller. Memory architecture is DDR2. Networking is Gigabit Ethernet. Power regulation uses VRD and Voltage Regulators. The board includes a Clock Synth., Differential Buffer DB800, System CPLD, PXH, FWH, Super I/O 373, MicroVu thermal sensor, and Fan PWM Controllers.
A: The board number is C8358, revision A00-001.
Q: What southbridge is used on this motherboard?
A: The southbridge is ICH5/ICH5R.
Q: What type of system management controller is used?
A: The system management controller is a BMC.
Q: What memory architecture does this board support?
A: This board supports DDR2 memory.
  • MSI C8358_x00 MS-9154-02S Rev X01 Schematic.pdf
  • MSI D1660 A03 MS-9154-020 Schematic.pdf
  • MSI MC871 MS-9154-040 Rev A00 Schematic.pdf
  • MSI MS-9154 Rev 10A Schematic.pdf
  • MSI MS-9154 Rev 110 Schematic.pdf
  • MSI MS-9154_120_C8358MS-A00-00 Schematic.pdf
