MSI GeForce GTX 1660 SUPER Gaming X MS-V375 2.2 Schematic
This MSI MS-V375 revision 2.2 motherboard, designed by MICRO-STAR INT'L CO.,LTD and dated Friday, August 23, 2019, is built around the NVIDIA Turing architecture featuring a TU106 6GB GDDR6 GPU with a 192-bit memory interface and X16 PCI Express lanes. The board integrates a comprehensive power supply subsystem including NVVDD, FBVDDQ, PEXVDD, and FBVDDQ PH2 rails, with multiple power phases for GPU core and memory voltage regulation. The schematic documents detailed power sequencing, voltage monitoring, and input power balancing with Type-C BuckBoost and hot-unplug protection. I/O connectivity includes DVI-D-DL, DP, HDMI, and USB-C interfaces, alongside thermal management, JTAG, GPIO, and ROM/XTAL/strap configuration support.
A: The board number is MS-V375, revision 2.2.
Q: What GPU type and memory configuration does this motherboard use?
A: The motherboard uses a TU106 6GB GDDR6 GPU with a 192-bit memory interface and X16 PCI Express lanes.
Q: What power supply rails are documented for this motherboard?
A: The schematic documents NVVDD, FBVDDQ, PEXVDD, FBVDDQ PH2, 5V, 1V8, NV3V3, 3V3_A, and 1V8_AON power supply rails.
| Brand | MSI |
| Motherboard Manufacturer | MICRO-STAR INT'L CO.,LTD |
| Board Number | MS-V375 |
| Revision | 2.2 |
| Date | Friday, August 23, 2019 |
| GPU Type | TU106 6GB GDDR6, 192b, X16 |
| Graphics Architecture | NVIDIA Turing |
