Schematic MSI G138M X00 MS-95R5-A20 Rev 0A 0B 0C Schematic
BrandDell Inc.
ModelR610
Motherboard ManufacturerDell Inc.
Board NumberD812F
RevisionX00
Date09/12/2008
Drawing Number123456
Document Number4321ABC1234DCB
Platform AliasThidwick & Zax 6 X 2.5 SAS BACKPLANE
PCH / SouthbridgeSAS X4
This Dell R610 backplane schematic, designated D812F revision X00, is dated September 12, 2008, and is identified as the Thidwick & Zax 6 X 2.5 SAS Backplane. The document, controlled under drawing number 123456 and document number 4321ABC1234DCB, details a 6-layer PCB stackup for a 2.5-inch SAS backplane. The board provides power distribution via +5V and +12V rails through a 2x7 right-angle Micro-Fit connector, with specific current ratings calculated at 9.38 A for +12V and 6.35 A for +5V. The backplane supports SAS X4 connectivity for up to six HDDs (HDD0 through HDD5) across two SAS cable connections, with integrated SAS HDD LED indicators and cable detection circuitry. The design leverages an I2C bus (I2C_BMC_ISO) for management communication and includes SEP (SAS Expander) power support.
Q: What is the board number and revision for this Dell R610 backplane?
A: The board number is D812F, revision X00.
Q: What are the power specifications for this backplane?
A: The backplane uses +5V and +12V rails via a 2x7 Micro-Fit connector, with calculated current capacities of 9.38 A for +12V and 6.35 A for +5V.
Q: How many SAS HDDs does this backplane support?
A: It supports up to six SAS HDDs (HDD0 through HDD5) across two X4 SAS cable connections.
BrandDell
ModelR610 SAS (6X2.5) Backplane
Board NumberWX005
RevisionX00
Date9/20/2007
Drawing Number4321ABC1234DCBA
Document NumberWX005
Platform Aliasthidwick-sas-backplane/"]11G Thidwick SAS Backplane[/URL]
PCH / SouthbridgeMX840DM334
RAM TypeRR808
This document details the Dell R610 SAS (6X2.5) Backplane, revision X00, dated 9/20/2007, with drawing number 4321ABC1234DCBA and document number WX005. The platform is identified as the 11G Thidwick SAS Backplane. The backplane features a 6-layer stackup and supports SAS connectivity for up to six 2.5-inch drives. Power is supplied via a 2x7 Micro-Fit right-angle header providing +5V and +12V rails. The design includes I2C bus connections for BMC and IOC communication, along with cable detection and SAS LED indicators for HDD0 through HDD5. The board is designed for Dell PowerEdge R610 servers.
Q: What is the board number and revision for this Dell R610 SAS backplane?
A: The board number is WX005, revision X00.
Q: What power connectors and voltages are used on this backplane?
A: The backplane uses a 2x7 Micro-Fit right-angle header providing +5V and +12V power rails.
BrandDell Inc.
Board NumberWX005
RevisionX00
Date9/20/2007
Document NumberRR808
Project Code11G Thidwick
Platform Aliasthidwick-6-x-25-sas-backplane/"]11G Thidwick 6 X 2.5 SAS Backplane[/URL]
PWB ColorRed with White Silkscreen
This document details the Dell 11G Thidwick SAS Backplane, designated as the R610 SAS (6X2.5) Backplane with board number WX005 and revision X00. The drawing number is 4321ABC1234DCBA, and the document number is RR808. The backplane is a 6-layer stackup designed for 2.5-inch SAS drives, supporting up to six SAS slots with integrated LED indicators for HDD activity and cable detection. Power is supplied via a 2x7 Micro-Fit right-angle header, providing +5V and +12V rails. The PWB color is specified as Red with White Silkscreen. The design date is September 20, 2007.
Q: What is the board number and revision for this Dell backplane?
A: The board number is WX005, and the revision is X00.
Q: What is the project code and platform alias for this backplane?
A: The project code is 11G Thidwick, and the platform alias is 11G Thidwick 6 X 2.5 SAS Backplane.
Q: What is the drawing number and document number for this schematic?
A: The drawing number is 4321ABC1234DCBA, and the document number is RR808.
BrandDell Inc.
Board NumberMX840DM334WX005RR808
Revision11G Thidwick 6 X 2.5 SAS Backplane
Date9/20/2007
Platform Aliasthidwick/"]11G Thidwick[/URL]
Charger Architecture+5V / +12V
Power IC(s)+5V, +12V
This Dell R610 SAS (6X2.5) Backplane, designated as the 11G Thidwick revision, is a Dell Inc. proprietary board identified by board number MX840DM334WX005RR808 and document number WX005. The schematic, dated 9/20/2007, details a 6-layer stackup design supporting SAS connectivity for up to six 2.5-inch drives. Power delivery is configured for +5V and +12V rails, with a 2x7 Micro-Fit right-angle header connector providing the main power input. The backplane integrates I2C bus lines for BMC communication and includes dedicated SAS slot and LED interfaces for HDD0 through HDD5. The drawing number is 4321ABC1234DCBA.
Q: What is the exact board number for this Dell backplane?
A: The board number is MX840DM334WX005RR808.
Q: What power architecture does this backplane use?
A: The backplane uses a +5V / +12V power architecture with a 2x7 Micro-Fit right-angle header connector.
Q: What is the document number and drawing number for this schematic?
A: The document number is WX005, and the drawing number is 4321ABC1234DCBA.
BrandDell
ModelR610
Project CodeThidwick (1U)
Board NumberMX848
RevisionA00
Date11/06/08
Document NumberMX848SCHEM
CPU PlatformPCI-Express Left Riser, Slot #2
This Dell R610 server schematic, designated MX848 Revision A00 dated 11/06/08, documents the Thidwick (1U) PCI-Express Left Riser Slot #2 planar connector board. The drawing number is 4321ABC1234DCBA, with the document number MX848SCHEM. The board is a Dell Inc. proprietary design manufactured in Round Rock, Texas, supporting a PCI-Express riser architecture for the R610 platform.
Q: What is the board number for this Dell R610 PCIe riser schematic?
A: The board number is MX848.
Q: What is the revision and date of this Dell R610 riser schematic?
A: The revision is A00, dated 11/06/08.
Q: What is the drawing number for this Dell R610 riser schematic?
A: The drawing number is 4321ABC1234DCBA.
BrandDell
ModelR610
Board NumberWX005
RevisionA00
Date10/20/2008
Document NumberMX840DM334WX005RR808
CPU PlatformSAS (6X2.5) Backplane
Power IC(s)J_BP_PWR
This Dell R610 SAS backplane, designated as the 11G Thidwick 6 X 2.5 SAS Backplane, is documented under board number WX005 revision A00, dated October 20, 2008. The drawing number is 4321ABC1234DCBA with document number MX840DM334WX005RR808. The backplane architecture supports a +5V / +12V power input configuration, with the primary power connector identified as J_BP_PWR. The design includes SAS cable detection circuitry and dedicated SAS HDD LED indicators for HDD0 through HDD5. The backplane utilizes a 6-layer PCB stackup and features I2C bus connections for BMC and IOC communication. The board is manufactured by Dell Inc. in Round Rock, Texas.
A: The board number is WX005 and the revision is A00.
Q: What is the power architecture of this backplane?
A: The backplane uses a +5V / +12V power input architecture.
Q: What is the platform alias for this Dell R610 backplane?
A: The platform alias is 11G Thidwick.
  • MSI G138M X00 MS-95R5-A20 Schematic.pdf
  • MSI MS-95R5 Rev 0A Schematic.pdf
  • MSI MS-95R5 Rev 0B Schematic.pdf
  • MSI MS-95R5 Rev 0C Schematic.pdf
  • MSI MX848 A00 MS-95R5 Rev 10 Schematic.pdf
  • MSI WX005 A00 MS-95R5 Rev 10 Schematic.pdf
