Lenovo Thinkpad L14 HL4A0-HL5A0 NM-D271 Schematic
The LC Future Center HL4A0/HL5A0 NM-D271 motherboard, revision 1.0 dated October 8, 2020, is built around the HL4A0/HL5A0 CPU platform. The system memory architecture consists of DDR4 organized into Sub Channel-A and Sub Channel-B. Discrete graphics is handled by an N18S-G5 GPU. The embedded controller is an NPCE68APA0DX, and the audio codec is an ALC3287. Power management is handled by a BQ25700A battery charger and multiple DC/DC converters including LV6228C, SYX198B, SY8310RAC, RT8068A, RT3613EE, RT9610CGQ, RT6543, NCP81278, MP2941, and BD9B304. The board features an HDMI Re-Timer (PS8409A), a GBE Jacksonville LAN controller, a Media Card Controller, and a USB TYPE-C RE-DRIVER.
A: The EC/KBC is an NPCE68APA0DX.
A: The audio codec is an ALC3287.
A: The charging IC is a BQ25700A.
Q: What type of RAM does this motherboard support?
A: This motherboard supports DDR4 RAM.
Q: What GPU is used on this motherboard?
A: The discrete GPU is an N18S-G5.
The LC Future Center NS-D271 motherboard, project code GL4A0XXXX, is documented under revision 0.1 dated 2019-06-25. The PCB name is GL4A0XXXX, and the board number is HL4A0 MB. The audio subsystem is built around the ALC3287 audio codec. The board integrates USB 3.0 and USB 2.0 ports, an Audio Combo Jack, and speaker output with OC signal monitoring. The schematic also references a Power board, MIC Sub board, and an Audio board B to B 60Pin connector.
Q: What audio codec is used on the NS-D271 motherboard?
A: The audio codec is ALC3287.
Q: What is the board number for the NS-D271 motherboard?
A: The board number is HL4A0 MB.
Q: What is the project code for this motherboard?
A: The project code is GL4A0XXXX.
This LC Future Center NS-D273 USB & Audio Board, revision 0.1, dated 2019-06-20, is a sub-board designed for the GL5A0XXXX PCB. The schematic identifies the board as part of the LC Future Center platform, featuring an ALC3287 audio codec. The block diagram indicates integration with a main power board, MIC sub board, and includes USB 3.0 and USB 2.0 ports, an Audio Combo Jack, and speaker connections with OC signal monitoring. The document is classified as LC Future Center Secret Data.
Q: What audio codec is used on this board?
A: The board uses the ALC3287 audio codec.
Q: What is the board number and revision?
A: The board number is GL5A0XXXX, revision 0.1, dated 2019-06-20.
This LC Future Center NS-D273 USB & Audio Board, revision 0.1, dated 2019-06-20, is a sub-board designed for the GL5A0XXXX PCB. The schematic identifies the board as part of the GL5A MBPower board and MIC Sub board system. The primary audio codec utilized is the ALC3287. The board integrates a USB 3.0 port, a USB 2.0 port, an Audio Combo Jack, and a speaker connector with SPK and OC signal lines. The block diagram also indicates a 60-pin board-to-board connector for audio board interconnection. The document is classified as LC Future Center Secret Data.
Q: What is the board number and revision for this schematic?
A: The board number is GL5A0XXXX and the revision is 0.1.
A: The audio codec is the ALC3287.
A: The document number is NS-D273.
| Brand | LC Future Center |
| Model | HL4A0/HL5A0 NM-D271 |
| Board Number | NM-D271 |
| Date | October.8.2020 |
| Document Number | NM-D271 |
| CPU Platform | HL4A0/HL5A0 |
| EC / KBC | NPCE68APA0DX |
| Audio Codec | ALC3287 |
| Charging IC | BQ25700A |
| Charger Architecture | Battery Charger |
| RAM Architecture | Sub Channel-A, Sub Channel-B |
| GPU Type | N18S-G5 |
| Graphics Architecture | N18S-G5 |
| dGPU Chip Number | N18S-G5 |
| Card Reader IC | Media Card Controller |
| LAN IC | GBE Jacksonville |
| WiFi / WLAN IC | WLAN |
| HDMI Level Shifter | HDMI Re-Timer (PS8409A) |
| USB Hub IC | USB TYPE-C RE-DRIVER |
| Thermal Sensor | Thermal Sensor |
| Power IC(s) | LV6228C, SYX198B, SY8310RAC, RT8068A, RT3613EE, RT9610CGQ, RT6543, NCP81278, MP2941, BD9B304 |
| Model | NS-D271 |
| Project Code | GL4A0XXXX |
| Board Number | HL4A0 MB |
| Revision | 0.1 |
| Date | 2019-06-25 |
| PCB Name | GL4A0XXXX |
| Document Number | NS-D271 |
| Model | NS-D273 |
| Board Number | GL5A0XXXX |
| Revision | 0.1 |
| Date | 2019-06-20 |
| PCB Name | GL5A0XXXX |
| Document Number | NS-D273 |
| Model | NS-D273 |
| Revision | 0.1 |
| Date | 2019-06-20 |
NM-D271
HL4A0
HL5A0
NPCE68APA0DX
ALC3287
BQ25700A
N18S-G5
N18S-G5
BD9B304
LV6228C
MP2941
NCP81278
RT3613EE
RT6543
RT8068A
RT9610CGQ
SY8310RAC
SYX198B
HL4A0 MB
NM-D271
HL4A0
HL5A0
NPCE68APA0DX
ALC3287
BQ25700A
N18S-G5
N18S-G5
BD9B304
LV6228C
MP2941
NCP81278
RT3613EE
RT6543
RT8068A
RT9610CGQ
SY8310RAC
SYX198B
HL4A0 MB
