Lenovo ThinkPad 11e 5th Gen, Yoga 11e 5th Gen 17833-1 Schematic
This Wistron Corporation document, dated Tuesday, December 12, 2017, covers the Leia-1PWRBT BD power button board, revision A416, with board number 17a55SD 1116. The board is part of the Leia project and includes a tact switch (SW1) with part number 062.40001.0D41, a 100R resistor (R101), and a connector (PW1) with part number 020.K0061.000. The schematic details the KBC_PWRBTN# signal routing.
Q: What is the board number and revision of this power button board?
A: The board number is 17a55SD 1116, and the revision is A416.
A: The document number is Leia-1PWRBT BD.
This document is a Wistron Corporation Leia-1 SENSOR BDA board, revision A3, dated Friday, November 24, 2017, with PCB number 17a54. The sensor board integrates a HGDEDM013A-GP Hall sensor for lid angle detection via I2C communication, and a BMA253-GP accelerometer. The default I2C address for the Hall sensor is 0x18 when the SDO pin is pulled to GND, with an alternative address of 0x19 selectable by pulling SDO to VDDIO. The board includes a 5-pin ACES-CON14-9-GP connector and a 24-pin ACES-CON24-15-GP connector for interfacing with the mainboard. Power rails include 3D3V_AUX_KBC, 3D3V_S0, and 5V_S0. The schematic notes indicate a change from 3D3V_AUX_S5 to 3D3V_AUX_KBC for SNR1.29 on the MB side.
Q: What is the PCB number for this sensor board?
A: The PCB number is 17a54.
Q: What Hall sensor is used on this board?
A: The Hall sensor is HGDEDM013A-GP.
Q: What accelerometer is used on this board?
A: The accelerometer is BMA253-GP.
Q: What are the I2C address options for the Hall sensor?
A: The default I2C address is 0x18 when SDO is pulled to GND, and the alternative address is 0x19 when SDO is pulled to VDDIO.
The Wistron Leia-1M motherboard, project code 4PD0DA010001 and board number 17833 revision -1, is built around the Intel Gemini Lake platform. The system is powered by a BQ25700ARSNR charging IC with BD2671 architecture and TPS51225BRUKR, BD2671, and G2898K power ICs. Memory configuration supports two DDR4-ODIMM channels. The embedded controller is a Nuvoton NPCE288, and the audio codec is a Realtek ALC3287-CG. The BIOS is stored on an 8MB SPI flash. Networking is handled by a Realtek RTL8111GUSI LAN controller and a Wireless LAN Antenna Type-E M.2 2230 module. The HDMI interface uses a PS8330 level shifter, and the card reader is controlled by an RTS5146-GR IC.
A: The BIOS is stored on an 8MB SPI flash.
A: The embedded controller is a Nuvoton NPCE288.
A: The charging IC is a BQ25700ARSNR, and the charger architecture is BD2671.
Q: What memory configuration does this motherboard support?
A: The motherboard supports DDR4 memory via two DDR4-ODIMM channels.
This Wistron Leia-1 Sensor Board, document number 17a54 revision A316 dated November 24, 2017, is a sub-board designed for sensor integration. The board features a HGDEDM013A-GP (074.00013.00) Hall sensor for lid angle detection and a BMA253-GP (074.00253.00) accelerometer for motion sensing, with an alternative accelerometer option of 074.00253.M001. The accelerometer communicates via I2C with a default address of 0x18 when the SDO pin is grounded, or an alternative address of 0x19 when pulled to VDDIO. The board includes a 5-pin ACES-CON14-9-GP (20.F1633.014) connector and a 24-pin ACES-CON24-15-GP (20.K0637.024) connector for interfacing with the mainboard, carrying signals such as LID_CLOSE#, ACCEL_INT, CPU_I2C_SCL_P5, CPU_I2C_SDA_P5, and USB4_USB20_CON. Power rails include 3D3V_AUX_KBC, 3D3V_S0, and 5V_S0.
Q: What is the default I2C address of the BMA253 accelerometer on this sensor board?
A: The default I2C address is 0x18 (0011000b), selected when the SDO pin is pulled to GND.
Q: What is the alternative I2C address for the BMA253 accelerometer?
A: The alternative I2C address is 0x19 (0011001b), selected by pulling the SDO pin to VDDIO.
Q: What Hall sensor is used on this Wistron Leia-1 sensor board?
A: The Hall sensor is the HGDEDM013A-GP, part number 074.00013.00.
Q: What accelerometer is used on this sensor board?
A: The primary accelerometer is the BMA253-GP (074.00253.00), with an alternative option of 074.00253.M001.
| Model | Leia-1 |
| Board Number | 17a55SD 1116 |
| Revision | A416 |
| Date | Tuesday, December 12, 2017 |
| Document Number | Leia-1PWRBT BD |
| Project Code | Leia |
| Model | Leia-1 |
| Board Number | SENSOR BDA |
| Revision | A3 |
| Date | Friday, November 24, 2017 |
| Document Number | 17a54 |
| PCB Number | 17a54 |
| Hall Sensor | HGDEDM013A-GP |
| Accelerometer | BMA253-GP |
| Model | Leia-1M |
| Project Code | 4PD0DA010001 |
| Board Number | 17833 |
| Revision | -1 |
| Date | Thursday, December 28, 2017 |
| CPU Platform | Intel Gemini Lake |
| EC / KBC | Nuvoton NPCE288 |
| Audio Codec | Realtek ALC3287-CG |
| BIOS / SPI Flash | SPI Flash 8MB |
| BIOS Flash Capacity | 8MB |
| Charging IC | BQ25700ARSNR |
| Charger Architecture | BD2671 |
| Power IC(s) | TPS51225BRUKR, BD2671, G2898K |
| RAM Architecture | DDR4-ODIMM1 CHA, DDR4-ODIMM2 CH |
| Card Reader IC | RTS5146-GR |
| LAN IC | RTL8111GUSI |
| WiFi / WLAN IC | Wireless LAN Antenna Type-E M.2 2230 |
| HDMI Level Shifter | PS8330 |
| Project Code | Leia-1 |
| Board Number | SENSOR B |
| Revision | A316 |
| Hall Sensor | [URL="https://dr-bios.com/components/thermal-fan/hgdedm013a-gp/"]HGDEDM013A-GP 074.00013.00[/URL] |
| Accelerometer | [URL="https://dr-bios.com/components/motion-sensor/bma253-gp/"]BMA253-GP 074.00253.00[/URL] |
| Accelerometer Alternative | 074.00253.M001 |
17A55SD 1116
17A54
HGDEDM013A-GP
BMA253-GP
Motion / Position Sensor
4PD0DA010001
17833
Gemini Lake
NPCE288
ALC3287-CG
BQ25700ARSNR
BD2671
G2898K
TPS51225BRUKR
RTS5146-GR
RTL8111GUSI
PS8330
LEIA-1
HGDEDM013A-GP074.00013.00
BMA253-GP074.00253.00
17A55SD 1116
17A54
HGDEDM013A-GP
BMA253-GP
4PD0DA010001
17833
Gemini Lake
NPCE288
ALC3287-CG
BQ25700ARSNR
BD2671
G2898K
TPS51225BRUKR
RTS5146-GR
RTL8111GUSI
PS8330
LEIA-1
Lenovo ThinkPad 11e 5th Gen, Yoga 11e 5th Gen 17833-1 LED Schematic.pdf115.2 KB · Views: 4
Lenovo ThinkPad 11e 5th Gen, Yoga 11e 5th Gen 17833-1 PWR Schematic.pdf70.6 KB · Views: 2
Lenovo ThinkPad 11e 5th Gen, Yoga 11e 5th Gen 17833-1 Schematic.pdf3.4 MB · Views: 3
Lenovo ThinkPad 11e 5th Gen, Yoga 11e 5th Gen 17833-1 Sensor Schematic.pdf132.4 KB · Views: 2
