Lenovo ThinkCentre M720q IQ3X0IL NM-B511 Rev 1.0 Schematic
This LC Future Center Tiny50.7 motherboard, project code EQ3700.7, board number D162 revision 0.7, is built around the Intel Coffee Lake-S platform with an LGA 1151 socket and Intel PCH 300 series chipset. The system memory architecture consists of two DDR4 SO-DIMM slots supporting up to 16GB per channel at 2400 MT/s. The BIOS configuration uses a dual SPI ROM setup with 128Mb plus 64Mb capacity. Embedded controller and thermal sensing are handled by the NCT6686D-L. Audio is provided by the ALC233-VB codec. Wired networking is managed by the Intel JacksonVille i219_LM LAN IC, while wireless connectivity is supported via an M.2 2230 slot for WiFi, Bluetooth, and CNVi modules. The charging and power architecture is IMVP8, utilizing the NCP81220 controller. The system also includes the RTS5449 for Type-C and card reader functionality.
A: The motherboard uses a dual SPI ROM configuration with capacities of 128Mb and 64Mb.
A: The embedded controller is the NCT6686D-L, which also handles thermal sensing.
Q: What is the charging architecture on this motherboard?
A: The charging and power architecture is IMVP8, controlled by the NCP81220 IC.
A: The wired LAN is provided by the Intel JacksonVille i219_LM.
| Brand | LC Future Center |
| Model | Tiny50.7 |
| Project Code | EQ3700.7 |
| Board Number | D162 |
| Revision | 0.7 |
| Date | 2018-01-05 |
| CPU Platform | Coffee Lake-S |
| CPU Socket | LGA 1151 Pin Socket |
| PCH / Southbridge | Intel PCH 300 |
| EC / KBC | NCT6686D-L |
| Audio Codec | ALC233-VB |
| BIOS / SPI Flash | SPI ROM 128Mb+64Mb |
| BIOS Flash Capacity | 128Mb+64Mb |
| LAN IC | Intel JacksonVille i219_LM |
| WiFi / WLAN IC | M.2 2230 WIFI / BT / CNVi |
| Charging IC | NCP81220 |
| Charger Architecture | IMVP8 |
| Power IC(s) | NCP81220 |
| Card Reader IC | RTS5449 |
| USB Hub IC | RTS5449 |
| Thermal Sensor | NCT6686D-L |
EQ3700.7
D162
Coffee Lake-S
LGA 1151
300
NCT6686D-L
ALC233-VB
JACKSONVILLE I219_LM
NCP81220
NCP81220
RTS5449
RTS5449
NCT6686D-L
EQ3700.7
D162
Coffee Lake-S
LGA 1151
300
NCT6686D-L
ALC233-VB
NCP81220
NCP81220
RTS5449
RTS5449
NCT6686D-L
