Lenovo Thinkbook14pro Gen2 Bitland HY410 Schematic
This Bitland 14P motherboard schematic, revision V1.3 dated March 15, 2021, is built on the AMD FP6 Cezanne H Platform with a Zen2 APU featuring a Vega7 GPU. The system utilizes DDR4 non-ECC memory in a Memory Down x1 configuration. The embedded controller is an ITE IT5576, and the audio codec is an ALC3287. The BIOS is stored on a 2MB SPI ROM. Power management includes a BQ25710 charging IC and RT8231 and RT3664BE power ICs. The board integrates a TUSB1044 HDMI level shifter, a TPS65988 USB hub/PD controller, an OZ711LV2LN card reader, and an NCT7718W thermal sensor. The LAN controller is a PS8409A, and wireless connectivity is provided via an M.2 WLAN/BT card.
A: The embedded controller is an ITE IT5576.
A: The BIOS is stored on a 2MB SPI ROM.
A: The charging IC is a BQ25710.
A: The board uses DDR4 non-ECC memory in a Memory Down x1 configuration.
| Brand | Bitland |
| Motherboard Manufacturer | Bitland Technology Co.,Ltd. |
| Project Name | 14P |
| Revision | V1.3 |
| Date | Monday, March 15, 2021 |
| CPU Platform | AMD FP6 Cezanne H Platform |
| Platform Alias | AMD FP6 Renoir H Zen2 APU Vega7 GPU 7nm |
| Graphics Architecture | Vega7 GPU |
| EC / KBC | ITE IT5576 |
| Audio Codec | ALC3287 |
| BIOS Flash Capacity | 2MB |
| Charging IC | BQ25710 |
| Power IC(s) | RT8231, RT3664BE |
| RAM Architecture | non-ECC |
| RAM Quantity / Slots | Memory Down x1 |
| Thermal Sensor | NCT7718W |
| Card Reader IC | OZ711LV2LN |
| LAN IC | PS8409A |
| WiFi / WLAN IC | M.2 Card (WLAN&BT) |
| HDMI Level Shifter | TUSB1044 |
| USB Hub IC | TPS65988 |
14P
Cezanne-H
Renoir-H
Vega7 GPU
IT5576
ALC3287
BQ25710
RT3664BE
RT8231
NCT7718W
OZ711LV2LN
PS8409A
TUSB1044
TPS65988
14P
Cezanne-H
Renoir-H
Vega7 GPU
IT5576
ALC3287
BQ25710
RT3664BE
RT8231
NCT7718W
OZ711LV2LN
PS8409A
TUSB1044
TPS65988
