Schematic Lenovo IdeaTab A10-70 A7600-F Compal GA-400 schematic
BrandCompal Communications, Inc.
ModelGA-400
Motherboard ManufacturerCompal Communications, Inc.
Project CodeLVP9/LVP0/LVPD
Board NumberBB-63NM_BB_P/N
Revision1.0
DateMonday, January 06, 2014
Document Number601B16CA
PCB NumberRF-X6RNM_RF_P/N
This Compal Communications GA-400 motherboard schematic, revision 1.0, is documented under document number 601B16CA and dated January 6, 2014. The project code is identified as LVP9/LVP0/LVPD. The PCB number is RF-X6RNM_RF_P/N, and the board number is BB-63NM_BB_P/N. The schematic includes a system block diagram, power tree definition, and pages covering the digital baseband, PMIC power, USB/charger, memory, audio, camera, LCM, RF transceiver, RF PA, RF front end, BT/WiFi/FM, GPS, sensors, keypad, SIM/uSD card, connectors, debug test points, and clock/others. The document also specifies mechanical parts including screw holes, pads, and shielding cases.
A: The document number is 601B16CA.
Q: What is the PCB number for this motherboard?
A: The PCB number is RF-X6RNM_RF_P/N.
Q: What is the project code for the GA-400?
A: The project code is LVP9/LVP0/LVPD.
  • Lenovo IdeaTab A10-70 A7600-F Compal GA-400 schematic.pdf
