lenovo ideapad 310 touch-15isk 510-15isk -ver 0xcn43ww dr- dump 8 mb
• If your Lenovo laptop shows Product Name, MTM, Lenovo SN or UUID as “INVALID”, the identity data inside BIOS/NVRAM/DMI may be missing or damaged.
• This can happen after motherboard replacement, wrong BIOS dump, incomplete programming, EEPROM/DMI editing error, or corrupted Lenovo identity area. The correct repair usually needs the original model data, serial information and a clean BIOS/DMI rebuild.
• Problems like “ME N/A”, missing MAC address, fan running at 100%, shutdown after about 30 minutes, or Intel ME related boot errors can be related to a damaged or unconfigured ME region.
• In many Lenovo repair cases, the ME region must be cleaned, rebuilt or configured correctly for the exact chipset and board. A random BIOS file may boot, but still leave ME, LAN MAC or thermal control problems.
• Lenovo BIOS password cases can include supervisor password, power-on password, system lock, EEPROM password data, or newer unlock cases on 9th and 10th generation platforms.
• These cases are security-sensitive and device-specific. For owned devices, the repair path may require BIOS dump analysis, EEPROM data check, Lenovo ID reset, buffer area cleanup, or a case-specific service file.
• If your Lenovo laptop always enters boot menu or BIOS setup when you turn it on, it may not be finding a valid boot device or boot configuration.
• First check whether the SSD/HDD/NVMe is detected in BIOS. Then check boot order, UEFI/Legacy mode, Secure Boot, Windows Boot Manager and storage health. If the problem started after BIOS work, NVRAM or boot configuration may need repair.
• Errors like “EFI PXE 0 for IPv4 boot failed”, missing hard disk, missing NVMe, or booting from network usually mean the system cannot boot from the internal drive.
• If the storage device and connector are healthy but Lenovo BIOS still does not boot correctly, the issue can be related to BIOS settings, NVRAM, corrupted boot entries, damaged BIOS region or incorrect firmware configuration.
• Slow boot, delayed display, long POST time, fan spin issues, or delayed Lenovo logo can be caused by BIOS corruption, ME region problems, EC firmware mismatch, bad NVRAM settings or unstable hardware detection.
• If basic hardware checks are normal, the BIOS dump, ME region, EC data and Lenovo identity area should be checked together. Fixing only the main BIOS region may not be enough.
ACHOTHANI , user3333 , smartechxasolutions , UgurKozlar , user50996 , Lokassou , phantom2002 , kewl07 , shafeek , user60332 , Naing , banofils , Salimeh Bolboli , reynaldo- , user31562 , user57813 , biltem teknoloji , Rohit suthar , Dariusz , xkod , user51149 , TurkeliBilgisayar , jeremyadams , user50571 , user6702 , ABEBE , LAPTOP LIFE CARE , user60331 , rezatel , WDCSE , user27655 , user57790 , user57871 , Vahab Hemmati , Errorkart , Sophonias Ethiopia , user6071 , cihan , sware , Compulaptop , user58894 , user13658 , user6856 , user61858 , user48033 , user61559 , user61935 , ericlin , Daniel melkamu , user24229 , user10018 , user24623 , user57657 , user57882 , mailabari , Ballack , SSV , HYLEON11 , SAQER BAKER , user56394 , user45133 , Mom chanto , Roollice , user51023 , user46825 , Mbuch , Kikungos , Tufan Teknik , Pozitif , Kanini Technology , shashighost , , user54378 , alexwm68 , Electronica360 , Muhammadyunus87 , user44938 , djmumay-28 , pete1979 , ELEVETUS TECH , onetouchcalicut , bonganinkosi , blessing senengo , probandoctm , gracia72 , Faizal , gabonisco , bando1120 , dfernandezd1995 , hossdevadm , bahtiyarusta , teafortwo , kaletek07 , Benzaoui , Malangdaman , rolandovillar , matus699 , wael daoud , vilmar 63
