lenovo ideapad 310-15isk lcfc by711 nm-a571
This Lenovo PND motherboard is built on the Intel Skylake-H platform with a 4+4e/4+2 processor configuration. The system memory architecture is DDR4 Dual Channel with 2 DIMM slots supporting up to DDR4 2133 MT/s. Graphics processing is handled by an nVIDIA dGPU N16E-GX with GDDR5 VRAM, connected via PCIe Gen3 x16. The embedded controller is an IT8376VG/CX. Audio is managed by an ALC3268 codec with TAS5766DCA and TPA3113D2PWP amplifiers. Networking includes a Killer E2400-RIVL-R LAN IC and an NGFF WLAN 2230 Type E connector. Storage connectivity supports SATA HDD/SSD, NGFF SSD 22280 Type M, and a Bayhub OZ620FJ1LN card reader. The charging architecture uses a TPS65982 Type-C controller. Thermal monitoring is provided by TMP006A sensors, and an RGB sensor CS5032 is present. The board also includes PS8331B MUX ICs and a PS8527C SATA redriver.
A: The embedded controller is an IT8376VG/CX.
A: The motherboard uses an nVIDIA dGPU N16E-GX with GDDR5 VRAM.
Q: What audio codec and amplifiers are used?
A: The audio codec is an ALC3268, with TAS5766DCA and TPA3113D2PWP amplifiers.
Q: What LAN and WLAN ICs are present?
A: The LAN IC is a Killer E2400-RIVL-R, and the WLAN uses an NGFF 2230 Type E connector.
Q: What charging IC is used?
A: The charging IC is a TPS65982 Type-C controller.
| Brand | LENOVO |
| Motherboard Manufacturer | LENOVO PND |
| Revision | V0.3 |
| Date | Wednesday, January 27, 2016 |
| CPU Platform | Intel Skylake-H |
| EC / KBC | IT8376VG/CX |
| Audio Codec | ALC3268 |
| RAM Architecture | Dual Channel 2 DIMM |
| RAM Quantity / Slots | 2 DIMM |
| LAN IC | Killer E2400-RIVL-R |
| WiFi / WLAN IC | NGFF WLAN 2230 Conn (TYPE E) |
| Card Reader IC | Bayhub OZ620FJ1LN |
| GPU Type | nVIDIA dGPU N16E-GX |
| Graphics Architecture | GDDR5 VRAM |
| Charging IC | TPS65982 |
| Thermal Sensor | TMP006A |
| RGB Sensor | CS5032 |
| SATA Redriver | PS8527C |
| Amplifier | TAS5766DCA |
| Amplifier | TPA3113D2PWP |
| MUX | PS8331B |
