ibm g41 quanta bf4 mb rev2a schematic 1
The Quanta BF4 motherboard is designed for the Mobile P4 prescott CPU platform using a Micro-FCPGA socket. The platform is built around the Montara-GT North Bridge and ICH4-M South Bridge, supporting DDR SDRAM 2.5V across two DDR-SODIMM slots. Graphics are handled by an NV34M GPU controller with AGP 4X at 266MHz and 1.5V, complemented by 64MB of dedicated video RAM. The system integrates a PC87551 KBC with EC functionality, a PC87391 Super I/O, and an AC97 audio codec paired with a TPA0312 audio amplifier. Networking is provided by a BCM5901KFB LAN controller and a BCM5705KFB Ethernet controller. The clocking solution uses an ICS950810BGT and ICS91718AM clock generator. A PCI1520 CardBus controller and Mini-PCI socket provide expansion capabilities.
Q: What EC/KBC is used on this Quanta BF4 motherboard?
A: The EC/KBC is a PC87551.
A: The GPU is an NV34M controller with AGP 4X at 266MHz and 1.5V, with 64MB of dedicated video RAM.
Q: What LAN and Ethernet controllers are used?
A: The LAN controller is a BCM5901KFB, and the Ethernet controller is a BCM5705KFB.
A: The motherboard uses DDR SDRAM 2.5V across two DDR-SODIMM slots.
| Brand | Quanta |
| Model | BF4 |
| Project Code | BF4 |
| Date | Monday, March 08, 2004 |
| CPU Platform | Mobile P4 prescott |
| CPU Socket | Micro-FCPGA |
| PCH / Southbridge | ICH4-M |
| North Bridge | Montara-GT |
| GPU Type | NV34M |
| Graphics Architecture | AGP 4X, 266Mhz, 1.5V |
| EC / KBC | PC87551 |
| Audio Codec | AC97 CODEC |
| Audio Amplifier | TPA0312 |
| LAN IC | BCM5901KFB |
| Card Reader IC | PCI1520 |
| Super IO | PC87391 |
| Battery Charger | BATTERY CHARGER |
| RAM Type | DDR SDRAM 2.5V |
| RAM Architecture | DDR-SODIMM |
| Video RAM | 64M |
| Thermal Sensor | CPU Thermal Sensor |
| WiFi / WLAN IC | Mini-PCI Socket |
| Ethernet Controller | BCM5705KFB |
