Hp Pavilion x360 18742-1 Schematic
This Wistron FAROE 14" Pavilion SA motherboard is an HP UMA platform documented on August 6, 2018. The system management is handled by a KBC9028Q EC/KBC, paired with an ALC3258 audio codec. Power delivery and charging are managed by an HPA02224 charging IC supporting both adapter and battery architectures. The memory subsystem consists of a single DDR4 SO-DIMM slot. Peripheral connectivity includes an RTS797ALGQW card reader controller, an RT9610BZQW LAN IC, and an SY6288C20AAC WLAN IC. An HDMI level shifter is provided by the G5416QS1U.
A: The motherboard uses a KBC9028Q EC/KBC.
A: The motherboard uses an ALC3258 audio codec.
A: The motherboard uses an HPA02224 charging IC.
A: The motherboard supports DDR4 memory via a single SO-DIMM slot.
| Brand | HP |
| Model | Pavilion |
| Project Code | FAROE 14" Pavilion SA |
| Document Number | A2103106 |
| Date | Monday, August 06, 2018 |
| CPU Platform | UMA |
| EC / KBC | KBC9028Q |
| Audio Codec | ALC3258 |
| Charging IC | HPA02224 |
| Charger Architecture | Adapter/Battery |
| RAM Quantity / Slots | 1 |
| Card Reader IC | RTS797ALGQW |
| LAN IC | RT9610BZQW |
| WiFi / WLAN IC | SY6288C20AAC |
| HDMI Level Shifter | G5416QS1U |
