Schematic hp pavilion dv6000 dv6700 quanta at3 rev1a schematic
hp pavilion dv6000_dv6700 quanta_at3_rev1a schematic
hp pavilion dv6000_dv6700=1=quanta_at3_rev1a.pdf
BrandQuanta Computer Inc.
Project CodeAT3
Board NumberNB5/RD1/HW2
DateTuesday, January 09, 2007
CPU PlatformMerom 478P (uPGA)/35W
NorthbridgeCrestline
SouthbridgeICH-8M
GPU Typenvdia-g3-64-for-15-4/"]NVDIA G3-64 for 15.4"[/URL] / NVDIA G3-128 for 17"
EC / KBCKB3926 Bx
Audio CodecALC 268
LAN ICRTL8101E/8111B
Card Reader ICRICOH 832
RAM TypeDDRII 533,667 MHz
RAM ArchitectureDDRII-SODIMM
RAM Quantity / Slots2
Charging ICMAX8724
Power IC(s)MAX8778, MAX1992, MAX8771, MAX8717, TPS51116
Clock GeneratorICS9LPRS355AGLF
WiFi / WLAN ICMini PCI-E Card
HDMI Level ShifterSI3080
The Quanta AT3 NB5/RD1/HW2 motherboard is designed for the Merom 478P (uPGA)/35W CPU platform with a Crestline Northbridge and ICH-8M Southbridge. Graphics options include NVDIA G3-64 for 15.4-inch configurations and NVDIA G3-128 for 17-inch configurations. The system uses DDRII 533/667 MHz memory in two DDRII-SODIMM slots. The embedded controller is a KB3926 Bx, and the audio codec is an ALC 268. Networking is handled by an RTL8101E/8111B LAN IC, while a RICOH 832 manages the card reader. Power management includes a MAX8724 system charger, with voltage regulation provided by MAX8778, MAX1992, MAX8771, MAX8717, and TPS51116 regulators. The clock generator is an ICS9LPRS355AGLF, and an SI3080 serves as the HDMI level shifter.
A: The motherboard uses a KB3926 Bx embedded controller.
A: The audio codec is an ALC 268.
A: The system charger is a MAX8724.
A: The LAN IC is an RTL8101E/8111B.
Q: What are the GPU options for this motherboard?
A: The GPU options are NVDIA G3-64 for 15.4-inch models and NVDIA G3-128 for 17-inch models.
  • HP Pavilion dv6000_dv6700=1=quanta_AT3_Rev1A.zip
