hp dv7 amd-jbk00 la-4093p_rev1.0 schematic
hp dv7=1=amd-jbk00 la-4093p_rev1.0.pdf
This Compal LA-4093P Rev 1.0 motherboard schematic, dated 2009-03-25, details a platform built around a Mobile AMD S1G2 CPU with ATI RX781 and SB700 core logic, paired with an ATI M86M discrete GPU. The system memory architecture is DDR2 Dual Channel, utilizing two DDR2-SO-DIMM slots. The embedded controller is a KB926, and the audio subsystem is managed by a 92HD71B7 codec. Networking is handled by a Realtek RTL8111C Gigabit LAN controller. The board also features a JMB380 card reader controller and an ADM1032ARMZ thermal sensor.
Q: What is the board number and revision for this Compal motherboard?
A: The board number is LA-4093P, revision 1.0.
A: The embedded controller is a KB926.
Q: What is the graphics configuration of this motherboard?
A: The motherboard uses an ATI M86M discrete GPU with ATI RX781 and SB700 core logic.
A: The motherboard supports DDR2 memory in a Dual Channel architecture, using two DDR2-SO-DIMM slots.
| Project Code | JBK00 |
| Board Number | LA-4093P |
| Date | 2009-03-25 |
| CPU Platform | Mobile AMD S1G2 CPU |
| PCH / Southbridge | ATI SB700 |
| GPU Type | ATI M86M |
| Graphics Architecture | ATI RX781 & SB700 core logic with M86-M |
| EC / KBC | KB926 |
| Audio Codec | 92HD71B7 |
| RAM Type | DDR2 |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| LAN IC | RTL8111C |
| Card Reader IC | JMB380 |
| Thermal Sensor | ADM1032ARMZ |
| Charging IC | TPA6020A2 |
| Power IC(s) | TPA3007D1 |
JBK00
LA-4093P
AMD S1G2
SB700
M86M
KB926
92HD71B7
RTL8111C
JMB380
ADM1032ARMZ
TPA6020A2
TPA3007D1
JBK00
LA-4093P
AMD S1G2
SB700
M86M
KB926
92HD71B7
RTL8111C
JMB380
ADM1032ARMZ
TPA6020A2
TPA3007D1
