hp 6530b 6730b dd08 6050a2154101-mb rrev a03 mv2 0623
This INVENTEC motherboard, project code CSA36911310, board number A21541-0-MTRA01 revision 269A3CSDD08 dated 21-May-2008, is built around the Intel Cantiga/Penryn CPU platform paired with the ICH9-M southbridge. Graphics are handled by a discrete NV100 GPU. System management is controlled by a KBC1070 EC/KBC. The audio subsystem uses an AZALIA_1984A codec. Power management is handled by a BQ24740 system charger and selector, with multiple power ICs including TPS51120, TPS51117, SC412A, ADP3209, ADP3208, and G2997. Memory configuration supports two DDR2 SODIMM slots. Networking is provided by a BCM5784 LAN IC and a Broadcom WLAN/WiMAX module. The board features an SMSC USB2228 card reader and USB hub, an ADT7421 thermal sensor, an STMicro LIS302DL accelerometer, an Agere FW322-07 1394 controller, a TPM V1.2 module, and an ICS9LPRS397 clock generator.
A: The motherboard uses a KBC1070 EC/KBC.
A: The charging architecture is a System Charger & Selector using a BQ24740 charging IC.
A: This motherboard supports DDR2 memory across two SODIMM slots.
A: The motherboard uses a discrete NV100 GPU.
| Brand | INVENTEC |
| Project Code | CSA36911310 |
| Board Number | A21541-0-MTRA01 |
| Revision | 269A3CSDD08 |
| Date | 21-May-2008 |
| CPU Platform | Cantiga / Penryn |
| GPU Type | NV100 |
| Graphics Architecture | Discrete |
| EC / KBC | KBC1070 |
| Audio Codec | AZALIA_1984A |
| BIOS / SPI Flash | FWH/SPI/HDD PROTECTION |
| Charging IC | BQ24740 |
| Charger Architecture | System Charger & Selector |
| Power IC(s) | TPS51120, TPS51117, SC412A, ADP3209, ADP3208, G2997 |
| RAM Type | DDR2 |
| RAM Architecture | DDR2 Interface, DDR2-SODIMM0, DDR2-SODIMM1 |
| LAN IC | BCM5784 |
| WiFi / WLAN IC | Broadcom (WLAN/WiMAX) |
| Card Reader IC | SMSC USB2228 |
| USB Hub IC | SMSC USB2228 |
| Thermal Sensor | ADT7421, STMicro LIS302DL |
| Super I/O | Super I/O (LPC, SPI, Serial debug) |
| DVI Controller | DVI CONTROLLER |
| 1394 Controller | Agere FW322-07 |
| TPM | TPM V1.2 |
| Clock Generator | ICS9LPRS397 |
| Document Number | A21541-0-MTR |
CSA36911310
A21541-0-MTRA01
Cantiga
Penryn
ICH9
NV100
KBC1070
AZALIA_1984A
BQ24740
ADP3208
ADP3209
G2997
SC412A
TPS51117
TPS51120
BCM5784
USB2228
USB2228
ADT7421
STMICRO LIS302DL
AGERE FW322-07
Bridge / Expander
TPM V1.2
ICS9LPRS397
CSA36911310
A21541-0-MTRA01
Cantiga
Penryn
ICH9
NV100
KBC1070
AZALIA_1984A
BQ24740
ADP3208
ADP3209
G2997
SC412A
TPS51117
TPS51120
BCM5784
USB2228
USB2228
ADT7421
STMICRO LIS302DL
AGERE FW322-07
Bridge / Expander
TPM V1.2
ICS9LPRS397
