Salimeh Bolboli
How To Solve “Product Information Not Valid” Issue In HP Laptop
If your HP laptop shows the error:
"Product Information Not Valid"
during BIOS updates, HP utilities, BIOS Configuration Utility (BCU), or hardware diagnostics, the issue is usually related to corrupted or missing DMI / SMBIOS information inside the motherboard firmware.
This is one of the most common problems after:
  • BIOS corruption
  • Motherboard replacement
  • SPI flashing
  • NVRAM erase
  • EC firmware repair
  • Wrong BIOS programming
What Is DMI / SMBIOS Information?
HP laptops store machine identity information inside the BIOS DMI region.
This includes:
  • Serial Number
  • Product Name
  • Product Number (SKU)
  • UUID
  • Feature Byte
  • Build ID
  • CT Number
  • System Board ID
If these values are erased or corrupted, HP tools cannot verify the machine identity anymore.
That causes errors like:
Code:
Machine is not configured
System Board CT Number Invalid
Feature Byte Missing
Common Causes
  1. Replacing motherboard without DMI programming
  2. Flashing clean BIOS dump without transferring original DMI
  3. Corrupted NVRAM region
  4. Wrong EC/BIOS combination
  5. Using BIOS from another machine
  6. Factory data erased during repair
Method 1 — Try HP BIOS Configuration Utility (BCU) First
BCU is the safest solution when DMI fields are still partially readable.
Export Current BIOS Information
Run Command Prompt as Administrator and execute:
Code:
BiosConfigUtility64.exe /Get:Config.txt
Open Config.txt and verify fields such as:
  • Serial Number
  • SKU
  • Product Name
  • UUID
If fields are editable, correct them using values from the laptop sticker.
Then write back:
Code:
BiosConfigUtility64.exe /Set:Config.txt
Reboot and verify in BIOS Setup (F10).
⚠ Important
BCU cannot repair fully erased or locked DMI regions.
If values stay blank after reboot, you must use HP DMI programming tools.
Method 2 — Use HP DMI Programming Tools
HP provides multiple generations of DMI tools.
Different notebook generations and ODM manufacturers use different utilities.
Main tools include:
  • WNDMIFIT
  • NbDmiFit
  • HP DMIFIT
  • HPSetCFG
  • BrandIT
Understanding HP ODM Manufacturers
HP does not manufacture all motherboards directly.
Different ODM vendors build different HP platforms.
Each family may require different DMI utilities.
PrefixODM Manufacturer
HPBCCompal
HPBQQuanta
HPBWWistron
HPBIInventec
HPBFOFoxconn
HPBFLFlextronics
HPBPPegatron
Example:
Code:
HPBQ174.exe
→ Quanta-based HP motherboard utility.
Code:
HPBC335.exe
→ Compal-based HP motherboard utility.
Which Version Should You Use?
There is no universal version that works on all HP laptops.
General guideline:
ToolRecommended Usage
NbDmiFit 1.xOlder HP laptops (2007–2012)</TD]
NbDmiFit 2.xMid-generation HP platforms</TD]
WNDMIFITBusiness HP models after 2011</TD]
HP DMIFITLegacy mixed platforms</TD]
[TD]
[TD]
[TD]
[TD]
Recommended stable releases:
  • NbDmiFit 1.14D
  • NbDmiFit 1.15
  • NbDmiFit 1.18
  • NbDmiFit 1.19
  • NbDmiFit 2.07
  • NbDmiFit 2.10
  • NbDmiFit 2.12
  • NbDmiFit 2.13
  • NbDmiFit 2.14-1
  • WNDMIFIT
⚠ Important
Some modern HP G3/G4/G5/G6 models may reject older NbDmiFit versions completely.
In those cases:
  • Use WNDMIFIT
  • Use correct Feature Byte
  • Verify MPM status
  • Check Intel AMT / AT configuration
NbDmiFit 2.14-1 EFI Method
Newer versions like NbDmiFit 2.14-1 use EFI boot mode.
Basic Procedure
  1. Extract package to FAT32 USB drive
  2. Enable EFI Boot Mode in BIOS
  3. Boot USB from F9 Boot Menu
  4. Run startup.nsh
  5. Choose VPRO or Non-VPRO configuration
  6. Commit AMT / AT data
  7. Lock descriptor
  8. Reboot system
If successful, you should see:
Code:
Pass!!! This machine is configured
Then disable EFI boot mode again if necessary.
Important Repair Notes
  • Always backup original BIOS before repair
  • Never use random Feature Byte values
  • Wrong UUID may break OEM activation
  • Wrong SKU may break HP driver detection
  • Feature Byte mismatch can disable hardware functions
  • Some systems require MPM unlock before programming
  • Some EliteBook models additionally verify Intel AMT state
⚠ Warning
Incorrect DMI programming may result in:
  • Missing wireless devices
  • Battery detection problems
  • Touchpad malfunction
  • HP Support Assistant failures
  • Windows OEM activation issues
  • BIOS update failures
Conclusion
The “Product Information Not Valid” error is usually not caused by Windows.
It is a motherboard firmware identity problem caused by missing or corrupted HP DMI information.
The correct solution depends on:
  • Laptop generation
  • ODM manufacturer
  • BIOS generation
  • MPM lock status
  • Intel AMT/VPRO support
For simple cases, HP BCU may be enough.
For deeper firmware repairs, professional DMI tools such as:
  • WNDMIFIT
  • NbDmiFit
  • HP DMIFIT
are required to fully restore motherboard identity data.
Technical data structured and organized by Dr-Bios.com, based on original firmware repair analysis and real-world board repair workflow experience.
Reuse permitted only with source attribution.
  • NbDmiFit1.19.zip
  • 2012_DMI_process.pdf
  • NbDmiFit-2.14-1.zip
  • All In One HP DMI Tool.zip
  • NbDmiFit-2.13 (1).rar
  • NbDmiFit_2.12.zip
  • NbDmiFit_2.10.zip
  • NbDmiFit_2.09.zip
  • NbDmiFit_2.08.zip
  • NbDmiFit_2.05.zip
  • NbDmiFit_2.07.zip
  • NbDmiFit_2.06.zip
  • NbDmiFit_2.03.zip
  • NbDmiFit_2.02.zip
  • NbDmiFit_2.01.zip
  • NbDmiFit_2.0F.zip
  • NbDmiFit_2.0A.zip
  • NbDmiFit_2.00.zip
  • NbDmiFit_1.19.zip
  • NbDmiFit_1.18.zip
  • NbDmiFit_1.45.zip
  • NbDmiFit_1.17.zip
  • NbDmiFit_1.1F.zip
  • NbDmiFit_1.15.zip
  • NbDmiFit_1.14D.zip
  • NbDmiFit_1.14D_2011.zip
  • NbDmiFit_1.1E.zip
  • NbDmiFit_1.14B.zip
  • NbDmiFit_1.1D.zip
  • NbDmiFit_1.1C.zip
  • hp DMI.rar
  • NbDmiFit_1.0B.zip
  • hp sn.rar
