haier thor 911-m5 quanta nl8b danl8bmb8d0
This Quanta NL8A motherboard is built around an Intel Haswell-H processor with a TDP of 47W in a BGA 1364 package, paired with an Intel Lynx Point-H PCH in an FCBGA695 package. The discrete graphics solution uses an NVIDIA N16E-GT GPU with 12 pieces of 4Gb GDDR5 memory. System memory consists of two DDR3L SODIMM slots supporting dual-channel architecture at 1600MT/s. The embedded controller is an IT8587, and the audio subsystem features an ALC283-CG codec with an ALC1003-VB-CG amplifier. Storage connectivity includes SATA and mSATA interfaces, while the BIOS is stored on an 8MB SPI flash. Networking is handled by a Realtek RTL8111GU LAN IC, and a Realtek RTS5227E card reader is present. The board also supports an M.2 2230 WiFi/BT module and HDMI 1.4a output.
A: The BIOS is stored on an 8MB SPI flash IC.
A: The embedded controller is an IT8587.
Q: What is the discrete GPU configuration?
A: The discrete GPU is an NVIDIA N16E-GT with 12 pieces of 4Gb GDDR5 memory.
A: The board supports dual-channel DDR3L memory at 1600MT/s across two SODIMM slots.
A: The audio codec is an ALC283-CG, and the amplifier is an ALC1003-VB-CG.
| Brand | Quanta |
| Model | NL8A |
| Project Code | NL8A |
| Document Number | NL8B Block Diagram |
| Revision | 1A |
| Date | Wednesday, January 14, 2015 |
| CPU Platform | Intel Haswell-H |
| PCH / Southbridge | Intel Lynx Point-H |
| GPU Type | NVIDIA N16E-GT |
| Graphics Architecture | GDDR5 4Gb X 12 |
| EC / KBC | IT8587 |
| Audio Codec | ALC283-CG |
| Audio Amplifier | ALC1003-VB-CG |
| BIOS / SPI Flash | SPI Flash (8MB) |
| Card Reader IC | RTS5227E |
| LAN IC | RTL8111GU |
| RAM Type | DDR3L |
| RAM Architecture | DDR3L CHA 1600MT/s, DDR3L CHB 1600MT/s |
| RAM Quantity / Slots | DDR3L SODIMM1, DDR3L SODIMM2 |
