Gigabyte B460M AORUS PRO DB Rev 1.02 Schematic
The Gigabyte B460M AORUS PRO D motherboard, board number 9MDB46MAPR-DB-10G with project code U19149, is built on revision 1.02 dated April 15, 2020. It supports Intel LGA1200 Comet Lake processors paired with the Intel B460 PCH. The system memory architecture consists of two DDR4 DIMM slots. Integrated graphics are provided by Intel HD Graphics, with display outputs including HDMI, DVI-D, and DP. The embedded controller is an ITE 8688, and the audio subsystem is driven by a Realtek ALC1200 codec. Networking is handled by an Intel I219V Gigabit PHY, with an M.2 slot for WiFi. The SPI BIOS flash is configured for 128M capacity. Power management is managed by ISL95866, RT8237, and RT8068A controllers. A Genesys GL850S USB 2.0 hub is present, and the HDMI level shifter is an IT5702.
Q: What is the board number and project code for the Gigabyte B460M AORUS PRO D?
A: The board number is 9MDB46MAPR-DB-10G, and the project code is U19149.
A: The embedded controller is an ITE 8688.
A: The SPI BIOS flash is configured for 128M capacity.
Q: What audio codec is used on the Gigabyte B460M AORUS PRO D?
A: The audio codec is a Realtek ALC1200.
Q: What LAN IC is present on this motherboard?
A: The LAN IC is an Intel I219V.
| Brand | Gigabyte |
| Model | B460M AORUS PRO D |
| Motherboard Manufacturer | Gigabyte |
| Project Code | U19149 |
| Board Number | 9MDB46MAPR-DB-10G |
| Revision | 1.02 |
| Date | Wednesday, April 15, 2020 |
| CPU Platform | Intel LGA1200 (Comet Lake) |
| PCH / Southbridge | Intel B460 |
| EC / KBC | ITE 8688 |
| Audio Codec | Realtek ALC1200 |
| BIOS / SPI Flash | SPI BIOS (128M) |
| BIOS Flash Capacity | 128M |
| LAN IC | Intel I219V |
| WiFi / WLAN IC | M.2 WIFI |
| USB Hub IC | Genesys GL850S |
| Charging IC | ISL95866 |
| Power IC(s) | ISL95866, RT8237, RT8068A |
| RAM Architecture | DDR4 DIMM x 2 |
| Card Reader IC | GL850S |
| Thermal Sensor | NTC |
| GPU Type | Integrated |
| Graphics Architecture | Intel HD Graphics |
| HDMI Level Shifter | IT5702 |
U19149
9MDB46MAPR-DB-10G
Comet Lake
B460
8688
ALC1200
I219V
GL850S
ISL95866
ISL95866
RT8068A
RT8237
GL850S
Intel HD Graphics
IT5702
U19149
9MDB46MAPR-DB-10G
Comet Lake
B460
8688
ALC1200
I219V
GL850S
ISL95866
ISL95866
RT8068A
RT8237
GL850S
Intel HD Graphics
IT5702
