fujitsu p7120 tiga main board schematic
fujitsu p7120=1=tiga main board.pdf
The Fujitsu Tiga Main Board (C1CP250040-X4 Rev.04) is a Pentium-M/Celeron-M Dothan-ULV platform using a u-FCBGA 478pin CPU socket. The graphics subsystem is driven by an Alviso-GMS North Hub in an FCBGA 840pin package, paired with an ICH6-M South Hub. System memory consists of two DDR2 uDIMM slots. The embedded controller is a LUNA2 PMU/KBC, while the PMU charging controller is a LUNA1. The BIOS flash is an SST49LF008A firmware hub. Audio is handled by an ALC260 codec with an LM4801MH amplifier. Networking is provided by an RTL8100CL LAN IC, and the system includes a MiniPCI slot for WLAN. A Ricoh R5C841 card reader controller and an SLD9630T TPM module are also present.
A: The BIOS flash is an SST49LF008A firmware hub.
A: The embedded controller is a LUNA2 PMU/KBC.
A: The charging controller is a LUNA1 PMU.
Q: What memory architecture does this motherboard use?
A: The motherboard uses two DDR2 uDIMM slots (uDIMM-0 and uDIMM-1).
| Brand | Fujitsu |
| Model | Tiga Main Board |
| Motherboard Manufacturer | Fujitsu Ltd. |
| Board Number | C1CP250040-X4 |
| Revision | 04 |
| Date | 2005.08.30 |
| CPU Platform | Pentium-M / Celeron-M (Dothan-ULV) |
| CPU Socket | u-FCBGA 478pin |
| PCH / Southbridge | ICH6-M South Hub |
| GPU Type | Alviso-GMS |
| Graphics Architecture | North Hub FCBGA 840pin |
| EC / KBC | LUNA2 |
| Audio Codec | ALC260 |
| BIOS / SPI Flash | SST49LF008A |
| Charging IC | LUNA1 (PMU) |
| RAM Type | DDR2 |
| RAM Architecture | uDIMM-0, uDIMM-1 |
| LAN IC | RTL8100CL |
| Card Reader IC | R5C841 |
| WiFi / WLAN IC | MiniPCI |
| Audio Amplifier | LM4801MH |
| TPM | SLD9630T |
C1CP250040-X4
Dothan-ULV
Pentium M
U-fcbga
ICH6
Alviso-GMS
LUNA2
ALC260
SST49LF008A
LUNA1
RTL8100CL
R5C841
MiniPCI
LM4801MH
SLD9630T
C1CP250040-X4
Dothan-ULV
Pentium M
U-fcbga
ICH6
Alviso-GMS
LUNA2
ALC260
SST49LF008A
LUNA1
RTL8100CL
R5C841
MiniPCI
LM4801MH
SLD9630T
