For understanding laptop schematic you must know abbreviation and short form name of the motherboard components. And it is kind of dictionary for technicians, so these are necessary for better understanding electronic data.
Hope it’s useful for you!
AC: Alternating current
ACDRV: AC adapter to system-switch driver output
ACEDET: Adaptor Current Detector
ACGOOD: Valid adapter active-low detect logic open-drain output
ACLN: Adaptor Current sensor Input
ACN: Adapter current sensor resistor
ACOP: Input Over-Power Protection
ACOV: Input Overvoltage Protection
ACP: Adapter current sense resistor, positive input.
ADP+: Adapter Positive Supply
ADP_ID: Adapter Identity
AGND: Analog Ground
ALWP: ALWAYS POWER ON
B+: AC OR BAT POWER RAIL FOR POWER CIRCUIT
BATT: Battery
BAT+: BAT POWER RAIL FOR POWER CIRCUIT
BAT_DRV: Bat Fe Gate Driver
BAT_V: Battery Voltage
BOM: BILL OF MATERIAL MANAGEMENT
BT: BUTTON
BT-EN: Bluetooth Enable
BUZER: Connected
BYP: Bay pass
CHGEN: Charge enables active-low logic input
CIN: Input Capacitor
CLK_EN: CLKOCK ENABLE
CN: CONECTOR
CRT: Cathode ray tube
CSIN: Current Sensor input Negative
CSIP: Current Sensor input Positive
DC: Direct current
DM: DIM DIM SOCKET SOKET MEMORY SOKET DDR
DOCK: DOCKING SOCKET
EC: Embedded Controller
EC_ON: Embedded Controller Enable
EMI: Electromagnetic Interference (GANGGUAN ELEKTROMAGNETIK)
EN: ENABLE
ENTRIP: Enable Terminal
F: FUSE
FSEL: Frequency Select Input
GATE: Trigger gate
GND: Ground
GP: GROUND PIN.
GPI: General Power Input
GPIO: General Power Input Output
HDMI: High-Definition Multimedia Interface
ID: Continuous Drain Current
IDM: Pulsed Drain Current
ILN: Operating Supply Current
ILN (SHDN): Shutdown Supply Current
ILN (STBY) : Standby Supply Current
IS: Continuous Source Current (Diode Conduction)
IVIN: Battery Supply Current at VIN pin
JP: JUMPER POINT
KBC: Keyboard Controller
UVLO: Input Under voltage Lock Out
LC DV: LCD POWER
V: RAIL (POWER)
LDO: Linear Driver Output
V+: Positive Voltage
LGATE: Lower-side MOSF ET gate signal
VADJ: Output regulation voltage
LPC: Low Pin Count
VALW: ALWAYS ON POWER
LVDS: Low-voltage differential signaling (SYSTEM VALWP VALW PAD PENSIGNALAN)
VBAT: BATTERY POWER
MBAT: MAIN BATTERY
VCCP: power chip (ich graphic chips)
NB: North Bridge
VCORE: POWER PROCESOR
ODD: OUTPUT DISC DRIVE
VDD: Control power supply
PCI: Penpheral Component Interconnect
VDDR: VDS DOWER DDR (VDRAMNRAMNMEM)
VDS: VOLTAGE DRAM SOURCE
PGOOD: Power good open-drain output
VFB: feedback inputs Power
PIR: PRODUCT IMPROVED RECORD
VG S: VOLTAGE GATE SOURCES
PSI#: Current indicator input
VIN: Input Voltage Range
PVC C: IC power positive supply
VIN: ADAPTER POWER SUPLAY (vol_in)
RSMR ST: Resume Reset
VL: Power Lock
R TC: REAL TIME CLOCK
VL: voltage across the load/Tegangan beban resistor
SB: South Bridge
VL: Voltage Linear
SHDN: Shutdown
VLDOIN: Power supply of the VTT and VTTREF output stage (to power MOS)
SYS_SDN: System Shutdown
VOT: Volt_out
SPI: Serial Peripheral Interface
VRAM: Power memory
VREF: POWER REFERENCES/SCHEMA REFERENCE/PERMINTAAN SKEMA
VS: SUITCH POWER
TD: Death Time
VS+: SUPPORT VOLTAGE POSITIF
THRM: THERMAL SENSOR
V SB: SOWER SWITCH BUTTON
TMDS: Transition Minimized Differential Signaling (TRANSMISI DATA TEKNOLOGY)
VSS: Signal ground
VSW: POWER SWICT
TP: TES POINT
VTT: Memory Termination Voltage
TPAD: THERMAL PAD
VTERM: Memory Termination Voltage
VUSB: POWER USB
VGA: POWER VGA (VGPXNGPUNCVOD)
VGFX: POWER GRAPHIC CHIP
VREF: VOLTAGE REFERENCES
C N=Connector
D=Diode
R=Resistor
C=Capacitor
U= (chip) IC
XIY= Crystal
UIQ= Mosfet
L= Coil
H= Hole
PAD = (pad)
SW = switch
PQ= Power Mosfet Big
PD= Power Diode
PU= Power IC
PR= Power Resistor
PC= Power Capacitor
PL= Power Coil
AGND: Analog Ground
BATT: Battery
BT: BUTTON
BUZER: Connected
BYP: Bay pass
CN: CONECTOR
DC: Direct current
EN: ENABLE
F: FUSE
GATE: Trigger gate
GND: Ground
GP: GROUND PIN.
JP: JUMPER POINT
LC DV: LCD POWER
V: RAIL (POWER)
LPC: Low Pin Count
VBAT: BATTERY POWER
MBAT: MAIN BATTERY
NB: North Bridge
VL: Power Lock
SB: South Bridge
VL: Voltage Linear
SHDN: Shutdown
VOT: Volt_out
VRAM: Power memory
VS: SUITCH POWER
TD: Death Time
VSS: Signal ground
VSW: POWER SWICT
TP: TES POINT
TPAD: THERMAL PAD
VUSB: POWER USB
C N=Connector
D=Diode
R=Resistor
C=Capacitor
U= (chip) IC
XIY= Crystal
UIQ= Mosfet
L= Coil
H= Hole
PAD = (pad)
SW = switch
PD= Power Diode
PU= Power IC
PR= Power Resistor
PC= Power Capacitor
PL= Power Coil
