dell vostro 3446 wistron cedar janus hsw 405070 schematic
dell vostro 3446=1=wistron cedar janus hsw 405070.pdf
This Wistron Janus HSW 40/50/70 motherboard, project code 4PD00I010001 and PCB P/N 13302-1 revision A00, is designed for Broadwell ULT processors. The platform supports both UMA and DIS graphics configurations, with a discrete NVIDIA N15V-GM-S-A2 GPU. System memory consists of DDR3L SODIMM modules. The embedded controller is an NPCE285P, and the audio codec is an ALC3234. The BIOS is stored on an 8MB Quad Read flash ROM. Power management is handled by a TPS51225RUKR-GP charger IC and multiple voltage regulators including the ISL95813HRZ-GP, HPA02224RGRR-1-GP, RT8237CZQW-2-GP, and TLV70215DBVR-GP. Networking is provided by either a Realtek RTL8106E (Cedar) or RTL8111G (Janus) LAN controller, with an 802.11a/b/g/n BT V4.0 combo WLAN module. The card reader uses a Realtek RTS5170, and the HDMI level shifter is an RTD2168. Thermal monitoring is handled by an NCT7718W sensor.
A: The BIOS flash is an 8MB Quad Read ROM.
A: The embedded controller is an NPCE285P.
A: The charging IC is a TPS51225RUKR-GP.
Q: What are the LAN IC options for this motherboard?
A: The Cedar variant uses a Realtek RTL8106E (10/100), while the Janus variant uses a Realtek RTL8111G (10/100/1000).
| Project Code | Janus HSW 40/50/70 |
| Board Number | 13302-1 |
| Revision | A00 |
| Date | Friday, February 07, 2014 |
| Document Number | 4PD00I010001 |
| CPU Platform | Broadwell ULT |
| CPU Model | CPU1B HASWELL-6-GP-U71.HASWE.G0U |
| GPU Type | NVIDIA N15V-GM-S-A2 GB2-64 ([URL="https://dr-bios.com/components/graphics-models/23x23/"]23x23) 25W[/URL] |
| EC / KBC | NPCE285P |
| Audio Codec | ALC3234 |
| BIOS Flash Capacity | 8MB |
| Charging IC | TPS51225RUKR-GP |
| Power IC(s) | ISL95813HRZ-GP, HPA02224RGRR-1-GP, RT8237CZQW-2-GP, TLV70215DBVR-GP |
| RAM Type | DDR3L |
| RAM Architecture | SODIMM |
| RAM Quantity / Slots | 2GB |
| Card Reader IC | RTS5170 |
| LAN IC | RTL8106E (Cedar), RTL8111G (Janus) |
| WiFi / WLAN IC | 802.11a/b/g/n BT V4.0 combo |
| HDMI Level Shifter | RTD2168 |
| Thermal Sensor | NCT7718W |
13302-1
Broadwell-ULT
23x23
N15V-GM-S-A2 GB2-64 25W
NPCE285P
ALC3234
TPS51225RUKR-GP
HPA02224RGRR-1-GP
ISL95813HRZ-GP
RT8237CZQW-2-GP
TLV70215DBVR-GP
DDR3L
RTS5170
RTL8106E
RTL8111G
n BT V4.0 combo
RTD2168
NCT7718W
13302-1
Broadwell-ULT
23x23
NPCE285P
ALC3234
TPS51225RUKR-GP
HPA02224RGRR-1-GP
ISL95813HRZ-GP
RT8237CZQW-2-GP
TLV70215DBVR-GP
DDR3L
RTS5170
RTL8106E
RTL8111G
n BT V4.0 combo
RTD2168
NCT7718W
